PCM pinout (shift light)
Old Mar 20, 2004 | 12:18 AM
JordonMusser's Avatar
JordonMusser
Default PCM pinout (shift light)
I need to know which connector, and which pin is the tach out for the shift light..
thanks
Old Mar 20, 2004 | 03:18 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: PCM pinout (JordonMusser)
On my '88 the Dist Ref Pulse Input goes into the ECM on the Ppl/Wht wire into pin C2. My ECM has no tach output signal.
A tach signal also goes to the Inst cluster on the white wire into pin C5 of the cluster assy.
Old Mar 20, 2004 | 03:43 PM
JordonMusser
Default Re: PCM pinout (65Z01)
wooops. I guess I shoulda noted this is for a 94, I am sure it is different. thanks tho!
Old Mar 23, 2004 | 09:09 PM
JordonMusser
anybody?
Old Mar 24, 2004 | 06:15 AM
FX GS's Avatar
FX GS
Take off the knee bolster on the drivers side. There is a mass of wires that comes thru the firewall right by the clutch pedal. The tach wire is the white wire, tap into this one. The pink wire is the hot, key on wire and then find a good connection for your ground wire.
Tie wrap the wires up there & then all is hidden under the dash, replace knee bolster and your're set to go. Nice & clean & you did'nt have to run anything thru the firewall.
Old Mar 24, 2004 | 10:30 PM
JordonMusser
Default Re: PCM pinout (FX GS)
sweet, cept I already have it run to the PCM area :-D
guess I can just pull it back through and wire it in there.
thanks
To PCM pinout (shift light)
