UPDATE 3 on missing engine ..arrrrghhhhhhh
Old Mar 20, 2004 | 01:00 AM
GhosTRydeR_92's Avatar
GhosTRydeR_92
Default UPDATE 3 on missing engine ..arrrrghhhhhhh
well guys ive got some good news and some bad news... ill go ahead and get the good news out ... I replaced both knock sensors and boths 02 sensors... reset the computer and started the car. :hurray: no codes where thrown i was happy about finally gettin rid of that damn SES light ..BAD NEWS... THE GOD FORSAKEN MISS IS STILL THERE! :cuss :mad :banghead: :banghead: :banghead: :banghead: :cuss
Old Mar 20, 2004 | 11:42 AM
GhosTRydeR_92
Default Re: UPDATE 3 on missing engine ..arrrrghhhhhhh (GhosTRydeR_92)
:confused:
Old Mar 20, 2004 | 11:50 AM
1990CORVETTE's Avatar
1990CORVETTE
does the light come on???????? at all???????????? have you taken it for a ride yet????????????
Have you pulled all the plugs, i would and check everyone ,,,,, check all the plug wires and connections, check all the vacuum lines
Old Mar 20, 2004 | 12:02 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: UPDATE 3 on missing engine ..arrrrghhhhhhh (1990CORVETTE)
I am guessing you have a '92 from your name..
Have you thought at all about the Opti?? Every time my opti has died, the big symptom was a miss.. and or backfire.. (last one, I had plumes of exhaust coming out of my intake!! Sometimes an opti will throw a code.. sometimes it wont.. :shrug:
Old Mar 20, 2004 | 01:59 PM
olman's Avatar
olman
Default Re: UPDATE 3 on missing engine ..arrrrghhhhhhh (MarkLT1)
No expert here, but I had a miss on my L98 that was rather elusive to the usual fixes that turned out to be a bad Accel injector with not that many miles on it. Yep, still runnin Accels. :smash:
Old Mar 20, 2004 | 03:09 PM
GhosTRydeR_92
Default Re: UPDATE 3 on missing engine ..arrrrghhhhhhh (olman)
its got a brand new opti on it so i know that not it along with new plugs and wires i replaced the 02 sensors and the KS ..no more codes at all im think i may have bad gas in it its been sitin for a year now :_dupe:
Old Mar 20, 2004 | 08:06 PM
GhosTRydeR_92
any one have a clue what to check now im totally bummfuzzled ! :confused: :cuss :_dupe:
Old Mar 20, 2004 | 09:06 PM
kman0066's Avatar
kman0066
Did you ever get to check your fuel pressure?
It's been sitting for a year. :eek:
Old Mar 21, 2004 | 12:46 AM
jfb's Avatar
jfb
Whenever you repair ANYTHING, never make assumptions about the condition of the parts. Even if your opti was 8 minutes old, it should still be suspect. I believe I have previously given you my advice and I haven't read anything about the results. Most misses are due to one or more spark plugs not firing. Even though your plug wires are new, unplug them one at a time and measure the resistance of EACH wire. They should measure about 5000 ohms per foot. That is how I found a bad Delco 1 week old plug wire on my 87. In the darkness with the engine running, see if there is any sparking along any of the plug wires. Plug wires have microscopic pinholes in them and if the wires are dressed too close to grounded metal, they may spark through the pinhole causing that plug not to fire.
[Modified by jfb, 11:47 PM 3/20/2004]
Old Mar 21, 2004 | 01:31 AM
GhosTRydeR_92
Default Re: UPDATE 3 on missing engine ..arrrrghhhhhhh (jfb)
WOW ! plug wires have microscopic pin holes!!!! damn i didnt know that !..Yeah its been parked for a year do to restoration work .. im finished now all i need is a paint job :thumbs: thanks for your help guys ill check out my fuel pressure first tomorrow and then im goin to pull all the plugs and check them all. and each plug wire... thanks again for ur help :cheers:
To UPDATE 3 on missing engine ..arrrrghhhhhhh
