'94 Stop light problem - help.
Old Mar 20, 2004 | 05:37 PM
John Row's Avatar
John Row
Default '94 Stop light problem - help.
The 4 stop lights on my 94 stopped working. Fuse is good. Turn signals work, emergency flashers work. The center stop light works.
The right front turn signal light went out now it's working.
I checked the wiring diagrams. It appears that the only thing that can cause the problem is in the "turn/hazard switch assembly".
Anyone, have experience with this little thing?
Thanks - JR
Old Mar 20, 2004 | 06:25 PM
jfb's Avatar
jfb
Default Re: '94 Stop light problem - help. (John Row)
More likely it is the brake light switch that is activated by the brake pedal. Either it is defective, out of adjustment (brake pedal is not activating it), or the wiring harness plug worked off it (unlikely). Unplug the connector on the brake light switch and jump the connections on the connector and observe if the brake lights come on. There are two sets of contacts in the brake light switch, one for the 4 lower brake lights and one for the high (or middle) brake light. When unplugged, you can use your ohmeter to test the brake light switch.
Old Mar 20, 2004 | 08:54 PM
sraft's Avatar
sraft
Default Re: '94 Stop light problem - help. (jfb)
:iagree: good possiblity it is the switch
JR,
The switch usually doesn't go bad, but the bracket that holds the stop light switch is an "el cheapo" plastic part (used to be metal, but GM probably figured they could save 2 pennies) that cracks and allows the brake light switch and/or the cruise control vacuum cut-off to go out of adjustment. It's ~$7 at the dealer, part #3537079.
You'll have to remove the DS knee bolster, lay on your back and get your head under there to verify and replace this part.
Old Mar 20, 2004 | 10:56 PM
John Row's Avatar
John Row
I'll check it.
The high brake light still works.
I didn't think it was the switch because the wiring diagram only shows one set of contacts at the brake switch.
Old Mar 23, 2004 | 04:10 PM
John Row's Avatar
John Row
... or the wiring harness plug worked off it (unlikely)...
This was it only it was on the turn signal/emergency flasher control switch.
Thanks.
To '94 Stop light problem - help.
