Diff Gear Oil Survey
Old Mar 20, 2004 | 05:56 PM
corvette1990's Avatar
corvette1990
Default Diff Gear Oil Survey
I am in middle of replacing my D36 with a D44, so therefore wish to hear what the majority of those who have changed gear oil are using. I have been told that you don't have to use the GM Posi Lube with Synthetic. WHat are the down sides to this? The D44 is being rebuilt with a 3.55 gear. Leaving me with a D44 3.07 gear, a D44 4.09 gear and a complete D36 3.07 set up. Thanks. Chris
Old Mar 20, 2004 | 06:10 PM
xs650's Avatar
xs650
Default Re: Diff Gear Oil Survey (corvette1990)
Regular old dinosauer squeezings are supposed to last the life of the car. Since I can't bring myself to leave diff lube in forever, I use a good brand of non-synthetic diff lube with anti silp additive.
I have never heard of one of these differential wearing out running on conventional diff lube. But, I'm sure I will now (breaking doesn't count) :rofl:
Old Mar 21, 2004 | 02:24 AM
86Moon's Avatar
86Moon
Default Re: Diff Gear Oil Survey (xs650)
Red Line with the additive, without was not happy, grinding on turns :hat It's all good now, and it was oh so much fun to change :rofl:
Old Mar 21, 2004 | 09:21 PM
Reno67's Avatar
Reno67
Used Mobil 1 Synth with the additive. Looks like alot of the others did too.
Old Mar 21, 2004 | 11:48 PM
wheelsup's Avatar
wheelsup
Chris , If you ask Carl S. he will tell you reg. lube with (2) bottles of additive. :eek:
Old Mar 22, 2004 | 01:10 AM
1990CORVETTE's Avatar
1990CORVETTE
Royal Purple for me :cheers:
Old Mar 22, 2004 | 01:35 AM
Mr6spd's Avatar
Mr6spd
Default Re: Diff Gear Oil Survey (1990CORVETTE)
Amsoil Synthetic . . . No additive was needed.
Old Mar 22, 2004 | 01:39 AM
frankrizzo1's Avatar
frankrizzo1
just changed my diff fluid....
used valvoline semi synthetic blend gear oil and 1 bottle gm posi additive.... :seeya
Old Mar 22, 2004 | 04:05 AM
ErnieN85's Avatar
ErnieN85
Default Re: Diff Gear Oil Survey (Mr6spd)
al these replys are ok if using mobil one 75-90 no additive is needed
Old Mar 22, 2004 | 05:13 AM
TA's Avatar
TA
Juust installed my rebuilt D44 and went with Mobil 1 and one bottle of posi additive. Seems great so far :thumbs:
Old Mar 22, 2004 | 05:41 AM
95coupe's Avatar
95coupe
redline 75w90 .no additive and no chatter. :thumbs:
Old Mar 22, 2004 | 10:32 AM
Ramanstud's Avatar
Ramanstud
Default Re: Diff Gear Oil Survey (95coupe)
What's the estimated capacity of a Dana 36? I know you're supposed to fill to the hole, but out of sheer curiosity what does this equate to? One bottle, 1.5 bottles of gear oil, etc?
Old Mar 22, 2004 | 04:09 PM
Tool's Avatar
Tool
Default Re: Diff Gear Oil Survey (frankrizzo1)
Wow. No offense intended guys, but this thread has my eyes rolling back in muh head! :eek:
Dyno, synthetic, semi-synthetic, w/lube, no lube... what's a poor boy to do? :confused:
I need to R&R my tranny and diff, and so I am very interested in this topic, but this is more bounce than asking which color is fastest! :flag
So let me - in my state of ignorance - ask this: where does one find GM Posi Lube? Dealer only?
Old Mar 22, 2004 | 08:55 PM
corvette1990
Default Re: Diff Gear Oil Survey (Tool)
I have been told two quart bottles of Diff oil and one small bottle of GM Posi lube will fill the diff on level ground. You can buy the GM Posi lube from summit/Jegs/GM Dealer/speed shops/ Richmond Gear/ Randys Ring and Pinion/ etc. I bought 2 bottles of Mobil One Syn gear oil and 1 bottle of GM posi lube. Waiting for the driveshaft to complete my rear swap. I bought 6 heavy duty Performance U-joints too. :party:
Old Apr 2, 2004 | 09:45 PM
corvette1990
Default Re: Diff Gear Oil Survey (wheelsup)
Well - after getting the rear diff rebuilt and back. The rebuilder (Carl) told me in no unceratin words "two bottles of regular oil and one of posi lube" This will wear the gear in properly for the first 1000 miles. Then you can switch to that fancy synthetic lube, suck it out with a slurp gun. The first 15 mins, I am supposed to start car up with wheels off the gound, put it in drive. That means I need to jack it up. put it on jack stands, plus jack up the A arms so they dont hang down while the half shafts are turning. Sounds like I need a few hydraulic floor jacks. :lol:
[Modified by corvette1990, 10:35 PM 4/4/2004]
Old Apr 4, 2004 | 04:33 AM
merrick's Avatar
merrick
:withstupid:
Old Apr 4, 2004 | 09:17 AM
Brimis's Avatar
Brimis
I went with the Mobil 1 with GM Posi Additive, works for me.
To Diff Gear Oil Survey
Old Apr 4, 2004 | 08:08 PM
bogus's Avatar
bogus
I use the Vavoline Synpower with GM posi additive... Gordon Killebrew recommends 2 bottles of the posi additive.
Old Apr 4, 2004 | 08:37 PM
myscx's Avatar
myscx
Default Re: Diff Gear Oil Survey (bogus)
Gordon Killebrew recommends 2 bottles of the posi additive.[/QUOTE]
:thumbs: Gordon says TWO bottles of posi additive and Gordon IS the MAN!!!!! :jester
Old Apr 4, 2004 | 09:06 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
quote:
Astro Glide and KY Jelly 50/50% mix with GM posi additive!
:iagree: :cheers:
