Emissions mods?
Old Mar 20, 2004 | 08:26 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
Default Emissions mods?
What kind of mods can be made to the emissions system to increase HP? I don't care if the EPA likes it or not, but I need to be able to undo the changes without too much trouble for when the car needs to pass inspection.
Old Mar 20, 2004 | 09:27 PM
rsafier's Avatar
rsafier
Default Re: Emissions mods? (ir0nmaiden420)
High-flow cat is probably the only one that is easy.
You could removing the AIR Pump, not really sure if there is a real gain out of doing it. But also as long as you don't have visual inspections you shouldn't have a problems passing without it as its only really active the first couple minutes to help heat up the cat quicker.
Old Mar 20, 2004 | 09:38 PM
vader86's Avatar
vader86
you should be able to pass NC emissions without precats, so you could do headers, then do a high flow main cat like Random Tech
I just dont remember if NC does a visual, you'd fail that with headers.
You can get rid of the AIR pump, but thats mostly a weight savings thing.
Old Mar 20, 2004 | 11:40 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I would agree that doing exhaust with FL headers and hi-flow cat & cat-back will net some very good results.
Also install a 160 deg F stat & fan switch.
You will gain a little by pulling the AIR pump but I don't think it's worth the hassle of putting it back on for inspection.
You also will need an AFPR to add more fuel at WOT to match increased air flow.
BTW, are you late '86 with Al heads?
Old Mar 22, 2004 | 04:52 AM
86PACER's Avatar
86PACER
[QUOTE I don't care if the EPA likes it or not, but I need to be able to undo the changes without too much trouble for when the car needs to pass inspection.[/QUOTE]
:lol: :lol: I'm with you :cheers:
Old Mar 22, 2004 | 04:56 AM
86PACER's Avatar
86PACER
ir0nmaiden420
I was not aware that NC had emissions testing. I lived in Onlsow County for 3 years while in the service and all we had to do was "Vehicle Safety Inspections" They cost about $10 just about anywhere and took about 5 minutes to do.
[Modified by 86PACER, 1:57 AM 3/22/2004]
Old Mar 22, 2004 | 05:27 AM
BIG JIM 54's Avatar
BIG JIM 54
Technically....
You can't do any changes to the emissions system on your car, even if the changes don't make any more polution. THAT'S what erks me. I believe it's everyone's responsibilty to make sure their car is running clean but if you change things to make your car run better/make more HP and if it still falls within the emission parameters set by the EPA for your year vehicle, so what?
The object of automobile emission laws is to make sure our cars don't polute beyond a reasonable amount. But if your car is still running clean, you should be able to do anything you want to it. It's your car.
But that's just me. Unfortunately, the EPA doesn't agree with the BIG JIM sense of logic.
Something I've done before if your car fails the visual but still passes the sniffer (although I'm not real proud of it) is pull the tester aside and slip him a C-note. The testing computer and the DMV won't know the difference and your car is still running clean. The only harm done is to your wallet.
BIG JIM
Old Mar 22, 2004 | 01:14 PM
ir0nmaiden420
Default Re: Emissions mods? (86PACER)
It depends on the county you live in. Generally the rural counties don't require emissions.
Old Mar 22, 2004 | 02:22 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
If you don't have to take a visual test, that's a plus.
Here's a copy of my test. Illinois Emission Test
I removed the AIR, EGR, pre-cats, and installed LT headers, a single hi-flow cat and Hotcam kit. When I took the test I was running 38 psi FP, timing was at stock 6 degrees and the idle was at 950 rpm's. As soon as I got home I bumped the timing to 10 degrees, raised the FP to 42 psi and just recently brought the idle down to 750.
oh yea I forgot, the test was taken w/ 2 gallons of 100 octane and 18 gallons of 93 octane.
[Modified by War Machine, 1:24 PM 3/22/2004]
To Emissions mods?
