lost torque
Old Mar 22, 2004 | 04:02 PM
88scryer88's Avatar
88scryer88
Default lost torque
I put stinger mufflers on my 88 L98 and lost torque. Any suggestions on a fairly inexpensive way to get it back?
Old Mar 22, 2004 | 04:08 PM
TA's Avatar
TA
Default Re: lost torque (88scryer88)
I got a way thats free, but you're not gonna like it...........put the stock system back on :crazy:
Seriously though, I can't see why you would have lost that much torque. Maybe a tad because of the free-flow mufflers, but it shouldn't amount to much. Have you had it to a dyno or to the track for before and after results? Maybe the loss is in your head.
Old Mar 22, 2004 | 04:10 PM
88scryer88's Avatar
88scryer88
Default Re: lost torque (TA)
It may be in my head but it feels like a lag when I punch it while moving. I just got it in November and never really noticed it before.
Old Mar 22, 2004 | 04:11 PM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
I'll bet the loss is in your head. I did before and after dyno results on my 90 vette. I went from stock exhaust to headers, no cats, muffler elims and true 2.5" duals and GAINED torque at every rpm.
Old Mar 22, 2004 | 06:03 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The only way to know if you gained or lost torque is on a dyno or drag strip. Of course if the mufflers are not hi-flow you could have lost torque due to back-pressure increase. Try removing the mufflers (open pipes for test purpose) to see if response is better.
Install an AFPR and bump fuel pressure a little.
Also check base timing; 6deg BTDC is stock and you might try 8deg BTDC.
Also check TPS base idle setting; stock is .54 Vdc and you might try .65Vdc for a little better throttle response.
Old Mar 22, 2004 | 07:05 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: lost torque (65Z01)
:iagree: try 8 deg BTDC :D
Old Mar 23, 2004 | 08:58 AM
88scryer88's Avatar
88scryer88
I put a hypertech chip in. I thought I may have read somewhere that if you have a chip not to advance your timing. Is this right or am I imagining things.
Old Mar 23, 2004 | 09:41 AM
Nathan Plemons's Avatar
Nathan Plemons
You could probably gain your performance back if you ditch the chip. Hypertech is notorious for giving up HP.
Old Mar 23, 2004 | 09:49 AM
88scryer88's Avatar
88scryer88
Default Re: lost torque (Nathan Plemons)
If that is the case what is gained by the chip. Just better gas mileage? I know you cant believe claims from manufacturers but they claim a horsepower increase.
Old Mar 23, 2004 | 10:03 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Sell your chip on ebay. Mod the car as you like it then get a real chip tuned specificlly for your car and mods here off the forum. Ski_Dwn_It did a fine job with the chip for my car and unlike the Hypertech, I had a very very long time ago, his chip actually increased the power.
:flag
Old Mar 23, 2004 | 10:38 AM
88scryer88's Avatar
88scryer88
Default Re: lost torque (VictorRussell'92)
Thanks...I'm pulling the chip tonight.
To lost torque
