vacuum line
Old Mar 23, 2004 | 08:41 AM
86_RedRider's Avatar
86_RedRider
Cruise-In V Veteran
St. Jude Contributor '03 & '05
Default vacuum line
I'm putting the upper intake back in on my 86 and I can't remember where the very rear line goes to. There was a line coming from near the wiper cover motor, but it was slightly twisted so i'm not sure if that is the one. here's a diagram of how i think it should go (the red line). is it right? if not, where does the line coming from near the wiper motor go and where does the one from the plenum to the HVAC go?
thanks.
[img]home.comcast.net/~jritter01/vacuumline.jpg[/img]
ps this diagram was posted by scorp, not sure if it's from a manual. but thanks for posting it anyways.
Old Mar 23, 2004 | 08:52 AM
86_RedRider
Cruise-In V Veteran
Default Re: vacuum line (86_RedRider)
not sure why the picture isn't showing up, but here's a link.
Old Mar 23, 2004 | 09:13 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
There are 2 ports on rear of plenum
One feeds air diverter and fuel reg and the other one is for the line you speak of.
:cheers:
[Modified by AGENT 86, 6:13 AM 3/23/2004]
Old Mar 23, 2004 | 09:29 AM
86_RedRider
Cruise-In V Veteran
Default Re: vacuum line (AGENT 86)
thanks, i had the first one, wasn't sure about the second. i need to replace it anyways, since i cracked it putting the fuel rail and runners back on. one more stop to the parts store and i should be done.
To vacuum line
