[L98] EGR Temp switch, how to replace?
Old Mar 23, 2004 | 02:05 PM
FlyboyZR1's Avatar
FlyboyZR1
Default [L98] EGR Temp switch, how to replace?
I was trying to get at the inside runner bolt for the drivers side, and in the process snapped off the wire going to the EGR temp switch. It looks like the "switch" is screwed into the EGR tube, and I won't have to remove the tube.
How do you remove it?
Old Mar 23, 2004 | 02:57 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Re: [L98] EGR Temp switch, how to replace? (FlyboyZR1)
Well I think I answered my own question, it screwed right out.
Off to the dealer!
Old Mar 23, 2004 | 03:07 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You will find that the problem remaining is that the damn harness connector is down behind the left side of the dist behind the intake base.
The best bet at this time is likely to cut off the connector on the new temp switch, splice it into the old wire and heat shrink the joint.
To [L98] EGR Temp switch, how to replace?
