Carb'd LT1 Question
Old Mar 23, 2004 | 03:25 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Carb'd LT1 Question
GM readily sells a LT1 carb intake. If you use this you can also use a regular distributor, doing away with the opti. The problem then what do you do about the timing cover? That's a rather large hole that the opti typically fills up. Will a normal SBC timing cover fit or do you have to modify the LT1?
Old Mar 23, 2004 | 03:37 PM
bogus's Avatar
bogus
Default Re: Carb'd LT1 Question (Nathan Plemons)
I don't think that intake is designed with a conventional distributor in mind.
Old Mar 23, 2004 | 03:40 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: Carb'd LT1 Question (bogus)
:lurk:
Old Mar 23, 2004 | 03:51 PM
MSR's Avatar
MSR
couldn't you just leave the opti there, but not doing anything? it couldn't hurt, right?
are you thinking of doing this swap? only thing i don't like is that they don't offer a single plane version.
-michael
Old Mar 23, 2004 | 04:15 PM
Ray383's Avatar
Ray383
If you are going to do away with the fuel injection and opti, wouldn't it just be easier/cheaper to use an earlier block?
Old Mar 23, 2004 | 04:23 PM
MSR's Avatar
MSR
Default Re: Carb'd LT1 Question (Ray383)
easier? probably not. one entails changing the fuel system and ignition source. the other entails swapping engines, accessories, a/c system, cooling system, as well as the fuel system and ignition. especially if one already has a stroker LTx engines with decent heads, making the switch is a pretty big step.
if you're starting from scratch, then the draw is much bigger. suddenly you can build a large bore engine, and have a huge variety of cylinder heads to choose from, not to mention better intake manifolds. if you are willing to do all the extra work for the hp gains, it's not a tremendous amount more expensive than building an LTx effort.
-michael
Old Mar 23, 2004 | 04:41 PM
Nathan Plemons
Default Re: Carb'd LT1 Question (MSR)
It's not for me at all. A friend of mine has a 3rd gen f-body that had a blown up 305. He got a 350 block but it turns out it's cracked. He can get a deal on an LT1 short block and he can get the heads really cheap too. He wouldn't have any of the electronics to make the fuel injection work, nor would he have the intake, etc. What he does have easy access to is a used carb, etc.
He can buy the engine and spend $250 on the carb intake and have the car running in no time. Then he can slowly piece together what he needs to make the fuel injection work again as he has the money.
You could just put an opti in there and leave it, but that requires having one. The LT1 carb intake is designed for a distributor so that's not a problem at all.
Old Mar 23, 2004 | 06:29 PM
crheinish's Avatar
crheinish
Yes you can use a conventional distributor with that intake and GM offers a timing cover for a carbed LT1/LT4. :cheers:
Old Mar 23, 2004 | 09:36 PM
Nathan Plemons
Default Re: Carb'd LT1 Question (crheinish)
That's good. I've never seen the timing cover, you wouldn't happen to have a part number, or know where to look for it?
Old Mar 23, 2004 | 09:47 PM
kman0066's Avatar
kman0066
It's actually just a cover for the existing cover. If you switch to an electric water pump, you can use a standard cover though.
GMPP part # 12367600 =Front cover/plug for covering the hole left on a 1996 LT4 engine when the distributor is removed and a rear mounted distributor is used.
They used to cost $45, but that was back in the day. I really don't even know if they carry these anymore.
Old Mar 24, 2004 | 08:47 AM
Nathan Plemons
Default Re: Carb'd LT1 Question (kman0066)
Very nice, that should be just what we need. I saw that and looked right over it, I was looking for something that actually looked like a timing cover!
To Carb'd LT1 Question
