Boring stock throttle body?
Thanks, Ray
:cheers:
He is attempting the same project
:cheers:
Reboring the throttle body is no BIG EFFORT!!!....However locating parts like Butterflies plates and bearings are somewhat hard...
some tips considering doing your own:
1:Either have the tools or a compentant machinist
2: you must know exactly what to do and when to do it
3: when boring the size of bore cannot exceed 52 mm, usually find the plates first or make your own, then do the bore to match
4: You must plug the egr hole before any boring and eliminate it only if you intend not to use egr!
5: bushings can be replaced instead bearing... in my opion bearings are over kill and the o-ring used to seal some bearing units are prone to failure
6: take your time!!!
This job is not for the average "joe", you must have the proper tools to proceed
the best advice is to learn all you can about this subject before attemping and ask yourself if you can do it,, If the outcome is "NO" i suggest you look to some of the compentant rebuilders mentioned here...Then ask a hole lot more questions about what rebuilder is going the do to your TB....ask about the process. maybe even ask about warranties....(very critical HERE!!)
As it was mention my attempt in rebuilding the TB is close as i wait for bearing and bushing to decise which to install.. i have made my own throttle plates using CNC milling cads...
Good luck!
plates are here http://www.holley.com/HiOctn/ProdLin...CA/26-100.html and here for 2 1/8" plates http://www.holley.com/HiOctn/ProdLin...CA/26-128.html ....
make sure to have the plates to your procession before boring!!!!!! these plates are not exactly 52mm , but it's equvialent,,, 2".. ther should be 2 to 3 thousandths of an inches clearance between bore and plate circumference..
NOT TRUE!!!! THE plates ARE ROUND !!! PERFECTLY ROUND.. and if in doubt measure them !!! I have taken the TBI apart and measured everthing....NO guessing here!!
as for sourcing in junk yard... forget it!! it would be quicker to make your own using a milling machine precsion circle cutter! dah!
hi Rich B.
