Need help with plenum
Old Mar 28, 2004 | 12:20 PM
jdevette1's Avatar
jdevette1
Default Need help with plenum
I need help getting the plenum off. I've removed 4 torx bolts from both the left and right side of the upper runners, took the line off the back on the left side, all vac. lines and connectors have been disc., I even removed the Throttle Body, I can't get it to budge, What am I missing or is there a trick to it? Any help would be great.
Old Mar 28, 2004 | 12:23 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Need help with plenum (jdevette1)
What am I missing ? Any help would be great.
Whack it with a deadblow hammer.
Old Mar 28, 2004 | 12:25 PM
tlc85's Avatar
tlc85
There are bolts on the backside. If your taking off the drivers side you have to reach these bolts from the passenger side and vise/verse. I think there are 2 or 3 bolts on the manafold on each side. hope this helps.
Old Mar 28, 2004 | 12:55 PM
1990CORVETTE's Avatar
1990CORVETTE
Default Re: Need help with plenum (JCAIRE2)
Yup :iagree: :beatdeadhorse:
Old Mar 28, 2004 | 01:10 PM
FlyboyZR1's Avatar
FlyboyZR1
Get your-self a big rubber mallet and smack that thing like you're really pissed. Hit it hard, but be careful as it is aluminum ... it will slowly pop loose. Mine was tough at first also.
Old Mar 29, 2004 | 07:53 PM
stock86vette's Avatar
stock86vette
Default Re: Need help with plenum (tlc85)
Thats only if your taking off your Runners as well. The inside bolts are @ the (inside) base of your runners and are threded into the intake manifold....Correct??? :thumbs:
Old Mar 30, 2004 | 02:20 AM
JAKE's Avatar
JAKE
Default Re: Need help with plenum (stock86vette)
On occasion I've had to loosen the lower runner bolts (runner to intake) in order to free the plenum.
Jake
Old Mar 30, 2004 | 11:24 AM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Default Re: Need help with plenum (JAKE)
Jake
:iagree:
I usually loosen the lower bolts, too. It is usually a pretty tight fit.
Old Mar 30, 2004 | 04:40 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Need help with plenum (Professor)
Looking down at the plenum... try to twist it counterclockwise slightly... this is the onnly way to get the brake booster fitting from clearing the runner flange without removing the distributor cap. The gaskets can be sticky.. so whack it gently with a dead blow or rubber mallet.
Also, the IAT sensor is plugged in undernneath... lift carefully just ennough to get your hand in there to unplug it.
Old Mar 30, 2004 | 05:36 PM
redfast's Avatar
redfast
Default Re: Need help with plenum (CentralCoaster)
I shoved a screwdriver inbettween the plenum and runners and twisted. After :beatdeadhorse: it and it poped off. I know its wrong....but I didn't care.
To Need help with plenum
