MINI-RAM...better than stealth or no?
Old Mar 28, 2004 | 09:57 PM
SHINOBI-X's Avatar
SHINOBI-X
Default MINI-RAM...better than stealth or no?
post says it all. and what cam would most of u MR people suggest running with a 1pc. 383 hyd.roller motor? its gonna see daily use prolly 3-5 days a week max and i want power,and nothing less than violent accleration either! thanx in advance!
Old Mar 28, 2004 | 10:25 PM
96LT1's Avatar
96LT1
Default Re: MINI-RAM...better than stealth or no? (SHINOBI-X)
You didn't mention whether you were running 1.5 or 1.6 RRs.
Comp Cams Extreme Energy
230/236 .510/.521 .544/.555 112 2200-5800
236/242 .521/.540 .555/.576 112 2500-6000
Crane
222/230 .509/.528 .542/.563 112 2000-6000
234/242 .539/.558 .574/.595 112 2500-6300
The 2nd column is with 1.5s, the 3rd is with 1.6s. The Crane 234/242 makes some awesome horspower but it doesn't really start coming on until 3000rpms.
The Comp Cams 230/236 and the Crane 222/230 are both very streetable and nice wide torque band.
Old Mar 28, 2004 | 10:51 PM
SHINOBI-X's Avatar
SHINOBI-X
Default Re: MINI-RAM...better than stealth or no? (96LT1)
thanx 96, i want a cam that generates power in the upper rpm band.ive only had experience with a few cam competators.crower and or STOCK! i'd like to try the Xtr.en. cams that COMP CAMS has to offer. i'd run the 284HR cam from comp w/ 1.6's. this motor will have true dual exhaust and alot of other goodies.im planning on some AFR 210 heads aswell....yes thats a large set for street i know. but i said violent acceleration!! :crazy:
Old Mar 29, 2004 | 01:32 PM
96LT1's Avatar
96LT1
i want a cam that generates power in the upper rpm band. ....yes thats a large set for street i know. but i said violent acceleration!! :crazy:
If thats what you want then go with the Crane 234/242 .574/.595. Retarding the cam by 4 degrees will move the power band 200 RPM higher up, say 2500 to 6500rpm.
You didn't mention if it was an auto or not. With the above setup and a 2600 stall convertor, you will be like :eek: :steering: :thumbs:
To MINI-RAM...better than stealth or no?
