First post Windshield Wiper Help
If you 94 is somewhat like my 86 it has three connectors. Two are easily seen because they are up top and plug into the black plastic cover.
The third one is at the very bottom of the motor and is hard to see and reach without removing the wiper motor from the firewall.
I suspect from your problem that the cruise control and wipers are on the same circuit You need to verify this and if they are, then the problem is cmmon to both of them.
A wiring diagram is what you need to be able to trace down the connections. I'll bet that someone on the Forum is familar with the wiring; hopefully he/she will respond with a post.
Jake
[Modified by JAKE, 3:31 PM 3/30/2004]
[Modified by tobijohn, 9:53 PM 3/31/2004]
"The cruise control set and engage switches are part of the multifunction turn signal lever assembly (smart switch) and are not servicable. The multifunction control lever must be replaced as an assembly..."
In the meantime, I'll keep looking for the CC diagnostics and schematics...
[Modified by tobijohn, 11:53 PM 3/31/2004]
