Engine oil
higher # the thinner it will be
A 5-30 will start out as a 5 viscosity, the thinnest/hottest it will get is 30 viscosity.
[Modified by Z-07 freak, 3:03 PM 3/30/2004]
:seeya
Multi viscosity oils work like this: Polymers are added to a light base (5W, 10W, 20W), which prevent the oil from thinning as much as it warms up. At cold temperatures the polymers are coiled up and allow the oil to flow as their low numbers indicate. As the oil warms up the polymers begin to unwind into long chains that prevent the oil from thinning as much as it normally would. The result is that at 100 degrees C the oil has thinned only as much as the higher viscosity number indicates. Another way of looking at multi-vis oils is to think of a 20W-50 as a 20 weight oil that will not thin more than a 50 weight would when hot.
5W30 : Same consistency as the 50 when cold.
5W50 : Thicker than the 30 when warm and will not pass through some of the smaller holes in seals, gaskets or piston rings that the 30 would. Run in higher mileage engines a lot of the times.
-michael
A 5-30 will start out as a 5 weight, the thinnest/hottest it will get is 30 weight.
The numbers indicate resistance to flow; viscosity.
The first number is an indication of resistance to flow at 32 degrees F; the second # is an indication of resistance to flow at 212 degrees F.
The higher the number the MORE resistant it is to flow; thus the pressure will be higher BUT the flow will be less.
If you'd like to see a detailed explanation of oil viscosities, you can probably find it on the sites of some of the big engine oil companies, such as Valvoline and Pennzoil.
So, a 5W 50 oil (if there is such an animal) will maintain higher oil pressure when the oil is really hot; higher than the 5W 30 will maintain.
The lower the first number (5W = 'W' standing for Winter) allows the oil to flow more freely in cold temps, making starting the engine easier and allowing better flow to the crucial parts.
Jake
it turns out that the "W" means that the oil passes the 32 degree F requirements set forth by the SAE for winter use. however, the number ratings preceding the W actually designate what the temp should be for the viscosity requirement.
that is (using bogus numbers just to have an example), a 10W has to meet certain viscosity requirements at -20 degrees C, and a 20W at -10 degrees C. this is tricky because it means an oil can actually meet various xW requirements simultaneously. for instance, an oil might be the correct viscosity to me rated as 10W, but also right to meet the 20W at the different measuring temp.
most 0W oils, for instance, are also 5W and 10W oils. in fact, you'll notice the 40 degrees C viscosity on many 0W oils is actually higher than some 5W and even some 10W oils.
what's interesting is that the xW designation has to meet certain minimum low shear requirements at 100 degrees C, but no maximum. this is basically how you get the 2nd number in a multigrade (along with high shear tests), they see what "weight" the oil meets for the 100 degree C test, and tack that on.
here's the API chart, although i don't think it's comprehensive. there are more requirements than this:
http://www.infineum.com/information/viscosity.html
-michael
-michael
You guys can check it out for yourselves and see if you can make heads or tails out of it.
Jake
