Auto vs. Manual
Old Mar 31, 2004 | 12:17 PM
jathomp's Avatar
jathomp
2nd Gear
Default Auto vs. Manual
Which C4's generally run faster times? I know a person with a auto vert with the 3.07 gears that says it's faster than any 6 speed stock. I think that a 6 speed with a good driver should beat an auto. The auto would be more consistent, but the faster times would be run by the 6 speed in my opinion. The guy with the auto vert also thinks that he will run low 13's very easily. I think that around a 13.7 would be more on target.
Old Mar 31, 2004 | 12:40 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Default Re: Auto vs. Manual (jathomp)
Generally a 6-speed will be quicker for a couple of reasons:
First, there is less driveline power loss so more HP reaches the rear wheels and
second, 6-speeds came with 3.45 rear ends so the ratios are better for quick launches.
It all comes down to the driver though. Mojo has pulled mid 12's on a stock LT1 6-speed but I'd say he knows how to drive down the strip!!
Btw, welcome to the forum! :seeya :hurray:
Old Mar 31, 2004 | 01:34 PM
allsop's Avatar
allsop
Cruising
Default Re: Auto vs. Manual (ShawnZR-1)
first of all what year does he have? with 3.07 i'm guessing he has 92-96 if his car is a 95 or a 96 car he should be hanging around 13.2. As far as if it can beat a same year lt1 with 6sp he will probably be right most of the time the auto will run a better ET, however the trap speed with that 6sp will probably be a bit more. For example a good run with a late c4 auto with 3.07 would be 13.2 or 13.3 a 6sp's ET will probably be hanging around 13.5 but his mph will the 6sp will be more so the auto shoulf be quicker.
i have a 95 automatic with 3.07 gears and it is 100% stock i got a 13.2 my first time.
Old Mar 31, 2004 | 01:43 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Default Re: Auto vs. Manual (allsop)
What kind of tires and what's your launch technique? Thanks...
Old Mar 31, 2004 | 01:51 PM
jathomp's Avatar
jathomp
2nd Gear
Default Re: Auto vs. Manual (tobijohn)
Thanks for the info guys. He has a 95 corvette convertible with the 3.07 gears.
Old Mar 31, 2004 | 03:34 PM
wildman738's Avatar
wildman738
any more op's on this?
[Modified by wildman738, 8:35 PM 3/31/2004]
Old Mar 31, 2004 | 03:36 PM
kittmaster's Avatar
kittmaster
there are a lot of thread on this topic if you use the search archives function, my vote is 6 speed all the way with the right techique
Kitt
Old Mar 31, 2004 | 03:37 PM
allsop's Avatar
allsop
Cruising
Default Re: Auto vs. Manual (wildman738)
as far as the tires there nothing special stock size goodyear eagle hp's. And he launch i just gave it a little gas to take up whatever slack there was and had the asr off it was my first run in this car and i got 13.2 so i was pleased.
Old Mar 31, 2004 | 03:39 PM
allsop's Avatar
allsop
Cruising
i meant to add if your posting this thinkg about buying a auto vs manual corvette for drag go with automatic you will be much happier i had a 6sp 94 and the best i ever got with it was a 13.5 and i hoped in my 95 auto and the first time got 13.2 so if you want to drag go with the automatic :thumbs:
Old Mar 31, 2004 | 03:49 PM
tobijohn's Avatar
tobijohn
Bench Racer
...the first time got 13.2 so if you want to drag go with the automatic :thumbs:
What was your 0-60ft time?
Old Mar 31, 2004 | 04:00 PM
allsop's Avatar
allsop
Cruising
2.132
Old Mar 31, 2004 | 04:25 PM
tobijohn's Avatar
tobijohn
Bench Racer
2.132
Wow! I've got zero experience drag-racing but from what I've read, if you got a 13.2 quarter-mile time and your 0-60ft was over 2.0 then you must have been really flying...
Old Mar 31, 2004 | 04:37 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
I love my manual 6 ! In my all stock 92 I was in Chicago a couple weeks ago and raced a new Zo6 from a light - I had a full tank of gas and a passenger - we both spun tires and launched at the same time, but I hooked up better and ran a carlength ahead through first and second - when we hit third he missed the gear and I jumped farther ahead then he finally passed me but I was pretty excited to hang with a 405hp Zo6 in my old C4 (58k miles all stock)
I think that an experienced driver can smoke someone who doesn't know what they're doing any day of the week even with 100hp difference
:party:
Old Mar 31, 2004 | 08:03 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VII Veteran
Welcome to the forum.
Old Mar 31, 2004 | 10:08 PM
Third Gear's Avatar
Third Gear
Default Re: Auto vs. Manual (mackeyred96)
Yeah, it just depends on what you like. You have more control with a stick that an auto. Auto can be just as quick if not faster with the right stall along with other supporting mods. Stick comes down to the driver's skill. :cheers:
Old Mar 31, 2004 | 10:20 PM
95_6spdvette's Avatar
95_6spdvette
I prefer a stick, ive ran 13.3's on a basically stock car. Muffler eliminators(which are suppose to hurt peformance) and a hypertech are the only mods and I couldnt get any traction. I say you go for the 6 speed, I think they are much funner!
Old Mar 31, 2004 | 10:22 PM
HTRK-1's Avatar
HTRK-1
Default Re: Auto vs. Manual (95_6spdvette)
:iagree:
To Auto vs. Manual
Old Mar 31, 2004 | 10:35 PM
samtron's Avatar
samtron
Default Re: Auto vs. Manual (HTRK-1)
well i have a 95 auto and a 96sp my wife has the 6sp and i have the auto 95. So, i can shed some light here hopefully we have taken both these cars to the track she is into corvettes as much as me :cheers: always a +! well my 95 auto convertible got a 13.4 i have ran her 96 6sp at the track the best i got was 13.6 the 95 has 72k miles on it the 6sp 96 as 57k on it so there both fairly low milage cars for the years so they a very strong running so if your asking which is quicker in the 1/4 i would say auto with 3.07 hands down.
Old Mar 31, 2004 | 10:46 PM
rideklein's Avatar
rideklein
Maybe an auto is a hair faster on the strip, but wouldn't you all rather take a 6spd through turns?
My vote is 6spd, of course.
Old Apr 1, 2004 | 11:37 AM
HeeHaw89's Avatar
HeeHaw89
Auto for drags all the way, though the 6spd for everyday would be my choice.
I have an auto and yes I enjoy driving it but I'd rather have a 6spd for around town.
