tunercat experts-help needed
i just purchased tunercat and it looks like a fine program...also the 8D file for my 90 L98
what confuses me, that in the ecm constants some values are a bit strange
when i load my stock bin (read it out from my chip) i get for example
Injector flow rate 221 / hour
Air-fuel ratio 1473
and a few more
it look like there are some values just multiplied wit 10, 100 or 1000
my question..is this a normal behavior, or will i have to change the values??
thank you
I haven't been here for a long time, so I'm just getting to you on this one.
By-the-by, there is a bit set for voltage to be checked either from the battery or the fuel pump. Address: L8016, bit 6.
I think it is zero for pump - 1 for battery. Next time you feel like changing the constants file, maybe you could add this one.
After adding all the tables you did to the last $8D file, you aren't going to believe it, but I have another one:
At address L8FF5: Decell Fuel Cut off Table.
When you feel like adding it, I would greatly appreciate it.
Thanks you for the program. It sure is alot easier than hacking through Hex code and trying to figure-out whether to drop a bit or not.
Once I learn how to tune this thing, I'm going to learn how to drive it.
