Bump up engine timing?
Old Mar 31, 2004 | 08:46 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
Default Bump up engine timing?
Someone suggested bumping up the engine timing to enhance performance-how much of a performance increase could this bring, and how would you do it on a 86? will it hurt the engine in anyway?
Old Mar 31, 2004 | 08:50 PM
DBLAZER4's Avatar
DBLAZER4
Default Re: Bump up engine timing? (ir0nmaiden420)
stock is 6. bump it up between 8 and 10. see which one you feel is best. i run mine between 12 and 14 but i have a miniram and it seems to like it better.
Old Mar 31, 2004 | 08:57 PM
CFI-EFI's Avatar
CFI-EFI
Just keep advancing until your 1/4 mile, mph's start to drop off. I'd start at 10. If it's faster than the stock 6, try 12. If not, back off to 8. I run mine at 14*, on 85 octane gasoline.
RACE ON!!!
Old Mar 31, 2004 | 11:02 PM
BookSmart's Avatar
BookSmart
Default Re: Bump up engine timing? (CFI-EFI)
I have also thought about doing this. I did this to a older car, just bumped it till I got spark knock or it wouldn't start. I ran premium tho. It helped a LOT.
One thing that helped give it timing was changing the advance curve in the HEI. Is this something that would help the Vette as well as bumping up the timing? Spring and weight kit costs like $5 at a parts store.
Old Mar 31, 2004 | 11:22 PM
vader86's Avatar
vader86
the actual performance gain, in terms of what you can feel, is not that much....ie, its not really something youll notice
it'll show up as another mph in a 1/4mi run and a little faster ET, thats about it
I keep mine at 8*
Old Apr 1, 2004 | 11:59 AM
CFI-EFI's Avatar
CFI-EFI
Default Re: Bump up engine timing? (BookSmart)
You need a new book, BookSmart. Write, when you find the centrifugal weights and springs in your electronic, C4, HEI, distributor.
RACE ON!!!
Old Apr 1, 2004 | 01:40 PM
Red Tornado's Avatar
Red Tornado
One thing that helped give it timing was changing the advance curve in the HEI. Is this something that would help the Vette as well as bumping up the timing? Spring and weight kit costs like $5 at a parts store.You need a new book, BookSmart. Write, when you find the centrifugal weights and springs in your electronic, C4, HEI, distributor.
RACE ON!!!
:eek: :lol:
Old Apr 1, 2004 | 01:48 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You have to give your engine the timing it "wants" for maximum performance. Several guys here have realy gotten a boost from bumping base timing.
So long as your knock sensor is in tact your engine will be safe.
Old Apr 1, 2004 | 07:22 PM
ENGINE TROOP's Avatar
ENGINE TROOP
Default Re: Bump up engine timing? (65Z01)
on that note 65Z01, would it be noticable if your timing was retarded if your knock sensor was sensing knock? just wondering.
Old Apr 1, 2004 | 09:54 PM
ir0nmaiden420
Default Re: Bump up engine timing? (ENGINE TROOP)
I don't think you are supposed to call it "retarded" anymore. its "slow"
:D
Old Apr 1, 2004 | 11:57 PM
BookSmart's Avatar
BookSmart
Default Re: Bump up engine timing? (bradvette)
I coulda swore I put weights in my 77 impalas HEI. I imagined they were the same. I am not confused and feel really silly. :confused:
Old Apr 2, 2004 | 01:43 PM
CFI-EFI's Avatar
CFI-EFI
You probably did. But your '77 Impala didn't have an ECM controlled spark advance. If your C4 distributor has a vacuum advance canister on the side, A. put an advance kit in it. And B. someone has changed your distributor.
Too much advance will cause knock. If the ECM gets knock counts it will pull timing. That will slow you down. Advance it to the point of greatest improvement in 1/4 mile mph's.
RACE ON!!!
Old Apr 2, 2004 | 02:13 PM
VAHROOM's Avatar
VAHROOM
Please also make sure your balancer hasn't walked. Sometimes the outer ring creeps a little bit making shecking with a light nothing but a good baseline. I put in the gas I am going to run. Loosen the hold down enough to tweak the timing. and take it out, let it worm up and go from there. I agree with the 1/4 mile time also. Or if you have a G-TECH the 60' times is a great tool.
Old Apr 2, 2004 | 02:51 PM
SHINOBI-X's Avatar
SHINOBI-X
Default Re: Bump up engine timing? (VAHROOM)
10 seems to be a good number for stock tpi's.when i put mine at 12 didnt' do me any better.G-TECH showed 2 tenths difference when i had mine at TDC and then i advanced it to stock imidiately when i noticed my timing was retarded that far. this is when i first bought my car,thats why it was like that! i'd shoot for 10 and try it.
Old Apr 3, 2004 | 12:45 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Bump up engine timing? (SHINOBI-X)
Can you feel, SOTP, timing being pulled at WOT? How much is it pulled, and for how long?
I want to know what to look out for...
I've also heard that simply hooking up an analog voltmeter to the knock sensor is a poor-man's tuning tool. Wouuld this be useful, or does a knock module further down the line actually differentiate the knock signals that are impossiblle for us to see on the VOM?
Old Apr 3, 2004 | 12:48 AM
CentralCoaster
Shinobi, when I use my Gtech for measuring gains, I use the HP setting.. and and always know my actual car weight +- 15 lbs, and adjust it for how much fuel I have.
I think the 1/4 mi MPH reading isn't as useful, cuz it varies more on your shift points and hole-shot. HP runs are more repeatable.
Old Apr 3, 2004 | 12:57 AM
olman's Avatar
olman
Default Re: Bump up engine timing? (CentralCoaster)
Just a note of caution :nono: Broken forged pistons and bent rods come from detonation. Ask how I know :cry
To Bump up engine timing?
Old Apr 3, 2004 | 01:03 AM
CentralCoaster
Default Re: Bump up engine timing? (olman)
:yesnod: Your knock sensor is not a cure-all. In order for there to detect predetonation, there must be predetonation occuring. :eek:
Old Apr 3, 2004 | 01:47 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Why?
:smash: :smash:
Old Apr 3, 2004 | 07:44 PM
ENGINE TROOP
speak up guys, can you feel the timing being pulled or do you need to hook into the knock sensor?
