30# SVO Injector Flow Rate
Old Apr 1, 2004 | 10:05 AM
mn_vette's Avatar
mn_vette
Default 30# SVO Injector Flow Rate
Does anyone know the exact rate of flow for the 30# SVO Injectors at 45psi? Are these injectors over rated, under rated? Thanks. :cheers:
Old Apr 1, 2004 | 11:47 AM
Half Fast's Avatar
Half Fast
Default Re: 30# SVO Injector Flow Rate (mn_vette)
I think ford rates them as 30lb at 38psi fuel pressure. FWIW I'm running mine at 48psi with an Ed Wright calibrated PCM to get the WOT A/F at 12.8.
Old Apr 1, 2004 | 12:02 PM
ToniH's Avatar
ToniH
I think Ford rates them at 39PSI. By using this as a base for calculations they would flow 32.22 lbs/hr at 45PSI.
Old Apr 1, 2004 | 12:54 PM
mn_vette's Avatar
mn_vette
Default Re: 30# SVO Injector Flow Rate (ToniH)
perhaps this is why I'm running a little rich, thanks guys 32.2 #/hr @45 it is then.
http://www.smokemup.com/auto_math/fu...ure_change.php
[Modified by mn_vette, 5:57 PM 4/1/2004]
To 30# SVO Injector Flow Rate
