Code 36-I'm Open To Suggestions
Old Apr 1, 2004 | 05:29 PM
GemVETTE's Avatar
GemVETTE
Default Code 36-I'm Open To Suggestions
I get the old "Service Engine" light a lot and clear it through the negative battery cable disconnect, but this week I had a guy hook up a code reading unit and it said "36". What do you guys think I should try first? Thanks
Old Apr 1, 2004 | 05:39 PM
leego's Avatar
leego
Default Re: Code 36-I'm Open To Suggestions (GemVETTE)
check this site out http://www.c4vettes.com/ecm.htm
Old Apr 1, 2004 | 05:48 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Replace the Mass Flow Burn-Off relay located behind the battery. It's the relay farthest from the fender well.
Old Apr 1, 2004 | 05:53 PM
GemVETTE's Avatar
GemVETTE
Default Re: Code 36-I'm Open To Suggestions (65Z01)
65Z01, is that an automatic change? It could not be anything else like a loose connection under the MAF, wire connection, relay connection? If I replace it then I won't have the code 36 again? Thanks.
Old Apr 1, 2004 | 05:56 PM
GemVETTE's Avatar
GemVETTE
Default Re: Code 36-I'm Open To Suggestions (leego)
Thanks Leego, I'll try these steps with a meter.
Old Apr 1, 2004 | 06:40 PM
vader86's Avatar
vader86
First step is to replace the relays behind the battery on the firewall.
Replace both, the code clears when you disconnect the battery for a few minutes, and it should not come back.
Together they are about $20.
If the code returns, its likely either the actual MAF or wiring.
To Code 36-I'm Open To Suggestions
