friend with a problem
Old Apr 2, 2004 | 12:07 PM
rick lambert's Avatar
rick lambert
Default friend with a problem
89 vette, seems his is blowing oil out of the dip stick when he kicks it down pretty hard, he noticed the plastic seal was cracked. What would cause it to blow oil out of the dip stick? :rolleyes:
Old Apr 2, 2004 | 12:11 PM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
Default Re: friend with a problem (rick lambert)
Check the pcv .. Sounds like the crankcase is pressurizing
Old Apr 2, 2004 | 12:15 PM
CFI-EFI's Avatar
CFI-EFI
Excessive crankcase pressure. Often caused by piston ring blowby.
RACE ON!!!
Old Apr 2, 2004 | 02:23 PM
purplemajesty's Avatar
purplemajesty
My dads '89 was springing leaks here & there (as well as out the dipstick) and as it turned out, the cats were almost completly clogged creating excessive crankcase pressure.
Old Apr 3, 2004 | 12:52 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: friend with a problem (purplemajesty)
Cats or pcv or bad rings.
Diagnose the pcv system first: If the pcv valve rattles, it's working.
Do a compression check next. Then squirt some oil into the cylinders with an eye dropper and do the compression check again. If you see significant PSI gains with the oil in there, rings are shot. Clogged cats shouldn't hurt the compression check numbers (unless they're completely plugged), since the engine doesn't flow hardly much air at cranking speed.
To friend with a problem
By Michael S. Palmer | 2026-06-03 11:00:24
