IN DEEEEEP DODOOOOOOO HELP!!!
Old Apr 2, 2004 | 06:49 PM
PUREC4's Avatar
PUREC4
Default IN DEEEEEP DODOOOOOOO HELP!!!
Taking of the air pump and assorted hardware. Right side next A/C compressor. Is this the air diverter switches. in a plastic box and has a short pipe to the air pump and a down pipe with a muffler of sorts. Can I un-plug them without causing codes. Do I just un-plug them and tie back the wire plugs. Or put all the crap back on? :cuss :cuss
Thanks in advance as always :flag
Old Apr 2, 2004 | 07:03 PM
MrNuke's Avatar
MrNuke
Default Re: IN DEEEEEP DODOOOOOOO HELP!!! (PUREC4)
You can take ALL of it off without any problems or codes.
I have last year when I put in an AirPump Eliminator kit.
Been working fine since..
Old Apr 3, 2004 | 12:40 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: IN DEEEEEP DODOOOOOOO HELP!!! (MrNuke)
yup, take it all off.
The crossover tube is the trickiest to remove, but worth it. The check valves on the smog trees are sufficient to block it off, but I removed them also, and capped the trees with polished stainless pipe caps from McMaster Carr.
Unfortunately, I live in Smogafornia, so I have all back on, temporarily. :mad
Now, tell me again why are you in deep doo?
Old Apr 3, 2004 | 12:56 AM
ZF Six's Avatar
ZF Six
Default Re: IN DEEEEEP DODOOOOOOO HELP!!! (CentralCoaster)
Yeah I ripped that bs off too, no problems. Saves like 5 pounds too! Well maybe not that much... but it's wieght reduction :smash:
Old Apr 3, 2004 | 05:38 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
No smog test's in your area?????
:confused: :confused: :confused:
To IN DEEEEEP DODOOOOOOO HELP!!!
