I didn't want to trust any dipstick. I filled the pan with oil before putting it on the engine and it took 6.5 quarts to go up to the windage tray. I'm running a 1/2 quart filter, so I put 7 quarts in. After first fill, I put my own mark on the dipstick knowing I had the right amount of oil in. 8.25 quarts seems like too much, unless you have a huge filter or cooling system.
that's pretty hard evidence, thanks. of course, the oil level drops significantly once the engine is running, but it probably doesn't drop 1-2 quarts worth. i need to rethink and probably just run 7-7.5 quarts.
my filter is significantly bigger, i can pour in 8/10ths of a quart before spinning it on. i suspect it takes another 2/10s once the engine runs and purges it completely. so your 6.5 in the pan plus 1 quart in the filter means i should try 7.5.
That's what I would do. I wouldn't just fill based on what the dipstick shows. The Canton pan is a total different shape so you really should recalibrate your dipstick. If you fill it any higher than the windage tray, you are just giving the crank a splash bath, and defeating the purpose of the tray. Now at speed not all of the oil is in the pan, but I see no reason to have more than 7-7.5 quarts in there unless you have a super high volume oil pump that would suck a canton pan dry :eek: .
When I received the pan I did what the above folks did-filled it up with water in quart increments until it was at the lower edge of the windage tray. That was 6.5 quarts. I then added the PF52 filter amount ~.5 quart. I then installed it on a fresh/dry engine, added 7 quarts and then to add some cushion for the kids, when I did my next oil change, I drained all I could, filled it again with 7 quarts and noted the dipstick mark-called that my 'full of oil' mark-I'm guessing it ended up 7.25 quarts-the 7 I added, plus the .25 or so that is stuck in the galleys, heads, valley, lifters, etc.
I don't why folks would not want to use the OEM dipstick. It works and sure beats crawling beneath the car to check oil...I could see me dropping it in the dirt or something...:)
thanks for the info, and my apologies if i came across in any way other than matter-of-factly. (i wasn't sure if your "since you asked nicely" comment was meant as a jab or not.)
does your oil level sensor read properly? mine inconsistently reads the level as being too low since the pan went on. the light comes on more often than not, actually, and i can't see a pattern between how long the engine sits and whether or not it complains. i also bought a new sensor, same problem. this was part of the reason i thought maybe i should be setting the level as the stock dipstick wants.
I agree with you 100%. It sounds like we did the exact same method, and I agree that if the stock dipstick works, use it. But just to clarify, I went with the canton dipstick because my stock one didn't work. There was a hole in the windage tray and for whatever reason when I got it all assembled the stock stick wouldn't hit the hole. It hit the tray and curved back up, so it read no oil at all on the stick. Not a good situation since you never know when you'd be low. So then I went with the Canton stick. Oh, and you don't have to crawl under the car to check the oil. Their add-on option is a tube that threads into the hole on the batwing and sticks up just like the stock tube, only on the driver's side. :cheers:
