Need Help with Cold Start Injector, and Temp sensor!
Old Apr 5, 2004 | 04:54 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Need Help with Cold Start Injector, and Temp sensor! (RED-85-Z51)
Your fuel system may not be priming properly...
Turn the key on, let it prime.. then key off. Wait till you hear the fuel pump relay click off.. (takes 5 seconds or so) then prime it again....
Now if it fires right up... it means you didn't have fuel pressure right away the first time. Bad check valve or leaky injector(s).
