Ebrake light at WOT!!!
Old Apr 7, 2004 | 06:22 PM
crheinish's Avatar
crheinish
Default Ebrake light at WOT!!!
Just took the car out for a triple digit blast and at WOT the emergency brake light comes on. Must be vacum related, any ideas? :skep:
Old Apr 7, 2004 | 06:30 PM
MSR's Avatar
MSR
Default Re: Ebrake light at WOT!!! (crheinish)
maybe your fluid level is low? some cars trip the light from a sensor in the reservoir.
-michael
Old Apr 7, 2004 | 06:37 PM
crheinish's Avatar
crheinish
Default Re: Ebrake light at WOT!!! (MSR)
Holly Smokes I bet you are right. :bb Thanks!
[Modified by crheinish, 3:54 PM 4/7/2004]
Old Apr 8, 2004 | 12:01 PM
Wheelman's Avatar
Wheelman
-michael
:withstupid:
There is a low brake fluid sensor mounted on the master cylinder. It triggers the same light as the e-brake I believe
Old Apr 8, 2004 | 09:26 PM
art1217's Avatar
art1217
Default Re: Ebrake light at WOT!!! (Wheelman)
Low fluid will also trip the ASR/ABS as well to prevent sucking air into the modulators. If you saw just the brake light, something other than fluid level could have set the light.
Old Apr 9, 2004 | 04:02 PM
crheinish's Avatar
crheinish
Default Re: Ebrake light at WOT!!! (art1217)
Low fluid is all it was. Thanks for the help guys. :cheers:
To Ebrake light at WOT!!!
