power seat stuck!
Old Apr 8, 2004 | 06:34 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: power seat stuck! (91drptop)
:cheers: I have a similar problem, but it doesn't buzz!
Any ideas?
:seeya
:steering:
Old Apr 8, 2004 | 07:10 PM
mn_vette's Avatar
mn_vette
Default Re: power seat stuck! (jackdaroofer)
Check out this post!
http://forums.corvetteforum.com/zerothread?id=680665
Old Apr 8, 2004 | 09:07 PM
monkeybusiness's Avatar
monkeybusiness
I posted this once before. Seat would go up but not down. Bought a complete switch harness. Upon disassembly...I found a dime stuck in the switch. Removed dime and sold the switch harness on the forum. Just a slight chance but worth a look. :lol:
Old Apr 8, 2004 | 09:13 PM
gr8n10city's Avatar
gr8n10city
My passenger seat goes up down but will not go forward or backward. I cannot remove the seat because I need to move it forward to get to the rear bolts. So, I cant replace the carpet until I figure out a way to get the seat out. Any one have any ideas?!
Old Apr 8, 2004 | 09:27 PM
lakerat's Avatar
lakerat
Default power seat stuck!
My driver's power seat will move every way except forward. I've fooled around with the switch, but the seat will only move forward occasionally. Not too worried about it because I'm the only one who drives it. But, being kind of picky, I'd like to get this fix. Any suggestions? :smash:
Old Apr 8, 2004 | 09:55 PM
91drptop's Avatar
91drptop
Default Re: power seat stuck! (lakerat)
If it buzzez when you select the switch to forward your gear is probably bound up. There is a gear that runs in a toothed track inside the track rails. A little grease should fix the problem. I recently took mine apart to repaint them and its pretty simple. 3 10mm bolts, a few spring clips, and two cotter pins.
Old Apr 9, 2004 | 08:29 AM
lakerat's Avatar
lakerat
Default Re: power seat stuck! (monkeybusiness)
Since I don't hear a Buzz, I assumed it was the switch. which I took apart and cleaned. Maybe, I'll give it another look. Thanks. BTW the post about the motors was very informative.
To power seat stuck!
