Have a stroked LT4, MAP at idle is 73. Using 1995 LT1 PCM. Per suggestion one of the members I changed RPM boundaries to 1200, 1600, & 2400 and changed MAP boundaries to 45, 65, 90. BLM enable temp and closed loop enable temp seem to be okay. VSS provides a signal but it is not accurate.
Using a scanner plus Datamaster the engine starts in open loop & transitions to closed loop. BLM is enabled. Computer only uses cells 16, 17 & 18. I never see the other cells. It uses cells 16 and 17 appropriately for idle and deceleration. Even in cruise stays in cell 18. I have the purge cannister turned off because I do not have one.
I would appreciate any suggestions about what to look at next. If the VE tables are off considerably, would the computer not go into cells 0 thru 15??
What cam are you using? For it to idle at a MAP value of 73 it must be a fairly large cam. Are you using a MAF sensor or are you running in Speed Density mode?
