85 Corvette Lights flickering
Old Apr 9, 2004 | 10:07 PM
knockretard's Avatar
knockretard
Default 85 Corvette Lights flickering
I have a 85 vette. The headlights and dash lights are filckering lightly. Does anyone know what this electrical problem could be?
Old Apr 9, 2004 | 10:35 PM
LD85's Avatar
LD85
Default Re: 85 Corvette Lights flickering (knockretard)
I had some issues when my Fuel Pump relay wires touched on the connector touched each other due to being stripped back from the connector too far. Dont know if this is it,,,,,
Old Apr 10, 2004 | 02:06 AM
StarShipCmdr's Avatar
StarShipCmdr
alternator
Old Apr 10, 2004 | 09:57 AM
1986Vette's Avatar
1986Vette
Alternator is easy enough to get checked out and is free at most parts stores, but I think you probably have a loose ground somewhere. I am experiencing the same problem here and I am convinced it's just a short somewhere or a loose ground. Not sure though the location of each ground or how many I need to look for.
Old Apr 10, 2004 | 01:11 PM
Jim Sitton's Avatar
Jim Sitton
Default Re: 85 Corvette Lights flickering (ld85)
Mine did that too. Was a bad alternator.
Old Apr 10, 2004 | 05:54 PM
okinawa86vette's Avatar
okinawa86vette
These cars act like that when the voltage is too low. My guess would also be the alternator going dead.
Chris
Old Apr 10, 2004 | 10:48 PM
knockretard
Default Re: 85 Corvette Lights flickering (okinawa86vette)
I am going to get the alt. checked out. I have a good voltage reading on the dash 14.9 to 14.7. I hope it is the alt and not a ground somewhere.
Old Apr 11, 2004 | 01:39 AM
jfb's Avatar
jfb
Most likely your alternator voltage regulator is oscillating and parts stores have no means to check for this. Proof is by unplugging your alternator with the engine running and seeing if the flickering stops. Or, better yet use an oscilloscope across the battery with the engine running and observe the amplitude and frequency of any alternating waveform on the battery.
Old Apr 11, 2004 | 01:50 AM
okinawa86vette
Default Re: 85 Corvette Lights flickering (jfb)
Ahhh....work flashbacks. I doubt an o-scope is part of very many amateur mechanic's tool box.
My car did the same thing when I put one of the higher power accel cap/rotors in the car. Put a stock ac/delco cap and rotor in it and it's been fine since. For some reason these cars are kinda sensitive to electronics.
Get a multimeter on the outputs of the alt and see what kind of voltage it's puting out there. You can also check the voltage accross the battery. If you use an analog multimeter, you should be able to see the fluctuations JFB is talking about, but obviously your not going to be able to measure it like you would with an o-scope. Normally, you should see a constant voltage accross the battery.
If you unplug the alt and the car runs the same or better, it's probably the alt. If it runs worse the alt's probably not your culprit.
Did you do anything to the car before it started happening?
Chris
[Modified by okinawa86vette, 12:52 AM 4/11/2004]
Old Apr 11, 2004 | 11:07 AM
knockretard
I tuned the car up, but it was flickering when I purchased the car. I am going to unplug the alt and see if that is the problem. I will keep you posted.
Old Apr 11, 2004 | 12:30 PM
knockretard
It was the altinator.
Thanks everyone!!!
To 85 Corvette Lights flickering
