Trickflow heads?
Old Mar 12, 2005 | 10:46 PM
88BlackZ-51's Avatar
88BlackZ-51
Originally Posted by tomcat-pilot
quote:
I probably would have purchased Trick Flows, but they don't do custom orders. My '90 has 58cc chambers stock, and 64cc is the smallest chamber they mfr. AFR & DART are the only two companies I've heard of that will accomodate custom orders. Just passing this on for information only
If you order from TEA or any other performance company with a machine shop, they will mill the heads to any chamber cc you want. I think milling .010 puts them at about 58cc chambers. Any machine shop can easily do this for minimal $$$.
i have not bolted the heads on the car yet, but i was impressed with the heads, they look purtdeeeee.
Old Mar 12, 2005 | 10:59 PM
Pete K's Avatar
Pete K
This is a blast from the past.
Old Mar 12, 2005 | 11:25 PM
vettmike's Avatar
vettmike
FWIT,
I have a used set of Trick Flow Heads for sale, the heads have less then 500 miles and really improved performance, they were removed from a friends vette due to class requirements, he had run the car in NCCC Group III and wanted to run Group II, so he removed the heads, one problem with these heads is you either run an aftermarket intake or you need to have a '87 or earlier manifold due to a difference in bolt angle on the center bolts.
These heads come with a fresh valve job, longer push rods and ARP head bolts. Also include all paperwork.
Price is $800.00 plus shipping.
vettmike
To Trickflow heads?
