brake pulse while turning hard.
Old Apr 13, 2004 | 12:03 AM
kwd1's Avatar
kwd1
Default brake pulse while turning hard.
I've noticed some pulsing in the brakes when braking and turning hard (at the same time). Anybody else get this? Brakes are fine otherwise.
I think it is most pronounced under the unusual situation where you apply the brakes after having started the turn. This happens sometimes when turning left across traffic and the 'hole' is not too big.
tia
Ken
Old Apr 13, 2004 | 01:15 AM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Re: brake pulse while turning hard. (kwd1)
Sounds like a warped rotor or possibly a wheel bearing going bad....any noise accompany the pulsing in the turn??
Old Apr 13, 2004 | 01:18 AM
BAM92's Avatar
BAM92
Default Re: brake pulse while turning hard. (MVR 155)
Is it pulsing like a bad rotor or your abs is kicking in?
Old Apr 13, 2004 | 01:51 AM
vetteseniorcit's Avatar
vetteseniorcit
Default Re: brake pulse while turning hard. (BAM92)
I agree that it is probably a warped rotor. Take it to a brake shop and have them do a "runout" check on your rotors. They can usually be turned and trued up on a lathe if they are within tolerance. Turning rotors and new pads will set you back about $600, most places. I had mine done at MIDAS since I plan to keep my 93 and the pads are guaranteed as long as I own the car.
Old Apr 13, 2004 | 02:02 AM
korvette4u's Avatar
korvette4u
I would also check for stuck brake guide pins while checking the rotor run out. run out should not be more then .005. just replace mine today!
Old Apr 13, 2004 | 06:08 AM
FX GS's Avatar
FX GS
:iagree: , especially if, as you say, you're braking HARD IN the turn. All your braking should be done BEFORE you enter the turn
Old Apr 13, 2004 | 06:51 AM
MrSpeedyBob's Avatar
MrSpeedyBob
You're tires have a certain amount of total traction that can be used in any direction. If you do a straight line stop all the traction is being aplied to stop the car and you can break fairly hard without causing a wheel to lock and triggering the ABS. If you're turning while you break a certain amount of traction is needed to turn the car, that leaves less available for breaking and the wheels will lock with less breaking force. At the extreem it is posible to corner hard enough that any breaking at all will cause wheel lockage and trigger the ABS.
Old Apr 13, 2004 | 08:01 AM
TA's Avatar
TA
Default Re: brake pulse while turning hard. (MrSpeedyBob)
Makes sense to me ;)
Old Apr 13, 2004 | 12:32 PM
John Row's Avatar
John Row
Default Re: brake pulse while turning hard. (vetteseniorcit)
... Turning rotors and new pads will set you back about $600, most places...
:eek:
Wow, I've got to get into the brake business... You can have the rotors turned at NAPA for about $20 and a good set of pads will run $100-$150 another $20-$70 for even expensive fluid and a set of new caliper pins is $20.
Old Apr 13, 2004 | 01:14 PM
69mako's Avatar
69mako
:withstupid:
Old Apr 13, 2004 | 01:25 PM
Total Recall's Avatar
Total Recall
Damn i get that too !
I know its not my abs kicking in though cos i can always hear the abs pump kick in when anything triggers the abs - but i definitely get a gentle pulse - like a warped rotor or something - when i turn and brake - although im usually only braking gently. I can`t figure out why if its a warped rotor it doesn`t do it when i brake in a straight line - ill have to get my bearings checked and guide pins replaced and c wots up too.
good luck
:seeya
Dom
To brake pulse while turning hard.
