Which gear for a good performance
Old Apr 13, 2004 | 01:11 PM
Dudule's Avatar
Dudule
Default Which gear for a good performance
Hi all,
I was wondering which gear to drive with if I want good acceleration and good top speeds...Like say driving sportly on a winding road...Drive or Overdrive ?
Old Apr 13, 2004 | 01:46 PM
bogus's Avatar
bogus
Default Re: Which gear for a good performance (Dudule)
Drive... the transmission has a tendency to drop into OD if you let it... fuel economy, don't you know...
Old Apr 13, 2004 | 02:12 PM
Dudule's Avatar
Dudule
Default Re: Which gear for a good performance (bogus)
I'm asking that cause I am used to manual clutch (I live in France)...
To summarize : I use OD to cruise and D to have fun...Isn't this right?
Old Apr 13, 2004 | 02:42 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Definitely use 3rd gear for cruzin the curves.
BTW, if you are handy with a Dremel tool you can cut some steps into your stock A4 shift gate to add shift feel. Then you can up/down shift with more confidence.
There are some pics of my modified shift gate on my site. Now I must use the button to down shift into 2nd or 1st; on up shift there is shift feel as the detent moves to each step. With my mod there is no step between 3rd & 4th but there is the indent stop at 2nd to tell me when I"m in 3rd.
This setup is nice if you like to approach sharp curves in the proper gear for maximum pull comming out.
[Modified by 65Z01, 3:19 PM 4/13/2004]
Old Apr 13, 2004 | 04:46 PM
Dudule's Avatar
Dudule
Default Re: Which gear for a good performance (65Z01)
What is your website ?...Is a 92 LT1 fit with an A4 shift gate ?
[Modified by Dudule, 12:09 AM 4/15/2004]
To Which gear for a good performance
