dyno in nor. va. area?
Old Apr 14, 2004 | 08:22 AM
93 ragtop's Avatar
93 ragtop
Default dyno in nor. va. area?
Where do you go for a dyno pull? Im actually in Manassas. Would consider Winchester area as well.
Old Apr 14, 2004 | 08:28 AM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Default Re: dyno in nor. va. area? (93 ragtop)
Hey Rich, how are ya? Goin to M-D this weekend?
To answer your question, check out Autothority in Fairfax, or Alexandria. They have had a couple of their Porsches make magazine articles.
Old Apr 14, 2004 | 08:52 AM
Crispyc21's Avatar
Crispyc21
Woodbridge Dyno and there is another mustang dyno place we go to in Springfield. I'm sure someone will correct me if I'm wrong or with more information.
Old Apr 14, 2004 | 08:57 AM
jerkyboy's Avatar
jerkyboy
Default Re: dyno in nor. va. area? (Crispyc21)
Woodbridge Dyno Tech south of Woodbridge
Curry's Auto in Sterling - Mustang Dyno
Total Performance - Mt. Airy MD - Mustang Dyno
Main St. Speed and Sound - Damascus MD - Dyno-jet
Tony's Corvette - Gaithersburg, MD - brand new Superflo
Old Apr 14, 2004 | 11:56 AM
96LT1's Avatar
96LT1
Actually if all you are looking for is a couple of pulls go to Excessive Motorsports in Manassas. http://excessiveonline.com/html/
If you are looking to have any wide band O2 readings, etc. contact John at Woodbridge Dynotech. http://www.woodbridgedynotech.com/
Old Apr 14, 2004 | 01:04 PM
sothpaw2's Avatar
sothpaw2
Default Re: dyno in nor. va. area? (96LT1)
I just dyno'd w/ John @ Woodbridge.
I was very satisfied with his work. That's why I drove over 100 mi to get there.
Old Apr 14, 2004 | 03:10 PM
96LT1's Avatar
96LT1
Default Re: dyno in nor. va. area? (sothpaw2)
:iagree:
John is about the only person I trust to work on my cars anymore.
Old Apr 14, 2004 | 03:23 PM
jerkyboy's Avatar
jerkyboy
Hey Mike. Does he do complete engine work as well or just tuning?
Old Apr 14, 2004 | 04:28 PM
96LT1's Avatar
96LT1
Default Re: dyno in nor. va. area? (jerkyboy)
Complete. He did the rebuild on my 396 when it spun a bearing. He does send the machine work out but he does everything else. He is a very compulsive individual in that he wants to do the job right and takes his time to do it.
He doesn't believe in taking short cuts and gets cranky (PO'ed) if you recommend it to him.
He installed my Accel DFI GEN VII on the 86 and really cleaned up a lot of the stuff left hanging by the last builder I used.
Old Apr 14, 2004 | 05:06 PM
luvmy92's Avatar
luvmy92
When did you spin a bearing? I didn't hear about it.
I have a couple of spun rod bearings as well, and am in the process of a 383 as we speak. I'll give you the details when we have it put together, but she should be a runner.
Mike
Old Apr 14, 2004 | 07:49 PM
96LT1's Avatar
96LT1
Default Re: dyno in nor. va. area? (luvmy92)
Mike
I thought everyone had heard about it. :mad (spun bearing, not everyone hearing about)
First event of the year, last run on the 2nd day at BeaveRun last year. I was playing with some Porsches in NASA Group III. Oil starvation because the Accusump was plumbed to the wrong location.
That was when I decided to let John the work on it and haven't looked back since. Besides correcting a half a dozen things that were wrong with the motor install he installed and set the tuning with the Accel DFI.
Tom Green took his race car down there and John started finding the same type of problems with his motor that were done on mine. Our motors are identical except for cams. From the dyno results, A/F ratios, etc., we are pretty sure that our "custom" chips were clones of each other.
Anyway to get this topic back on subject, John also managed to correct a problem with Tom's ABS that no one else had been able to resolve. Worked with (I think Ed Wright, someone out of Oklahoma) to get a 'good' chip burned. Found out that Tom was still running the stock fuel pump (not good for a 396), did a R&R with a Walbro and a couple of other little things.
So needless to say I am singing John's praises now a days.
Old Apr 14, 2004 | 09:30 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
http://www.springfieldmotorsport.com
Springfield Motorsport - dyno is 3 pulls for $75 and an additional $25 for an accurate Air/Fuel measurement WITHOUT adding a bung (uses a tail sampler & is accurate - proven)
I95 & Terminal Rd by the "tank farm" :flag
Old Apr 14, 2004 | 10:32 PM
96LT1's Avatar
96LT1
Default Re: dyno in nor. va. area? (*89x2*)
:nonod: :nonod: :nonod: :nonod:
Old Apr 14, 2004 | 10:57 PM
*89x2*'s Avatar
*89x2*
Jon has been VERY good to us whenever we wanted baselines -
RKreigh laid down 505hp to the rr wheels last time we went down there :eek: and only charged us something like 50 bucks for 3 pulls - Including the A/F ratio - as we had a few cars ;)
Old Apr 15, 2004 | 07:21 AM
93 ragtop's Avatar
93 ragtop
Default Re: dyno in nor. va. area? (RainDelay)
[QUOTE]Hey Rich, how are ya? Goin to M-D this weekend?
QUOTE]
I dont believe I am going to be able to make it. Is this one open to everyone or did you need to reserve in advance? If work load changes I would like to go. Let me know how you do.
Old Apr 15, 2004 | 07:23 AM
93 ragtop's Avatar
93 ragtop
Thanks to everyone for their suggestions. I didnt realize there was that many dynos in the area. I want to get a reading and fuel reading as well and then get my chip fine tuned a little by Jesse (ski-down-it)
Old Apr 15, 2004 | 07:34 AM
jerkyboy's Avatar
jerkyboy
Tony's Corvette is setting up their dyno to burn chips in your car while on the dyno. If I hadn't already pulled the trigger on a DFI system, I would definately go there.
To dyno in nor. va. area?
