overheating on '94
Old Apr 14, 2004 | 10:57 AM
Johnk's Avatar
Johnk
1st Gear
Default overheating on '94
I have a problem with overheating when I do not have the air-conditioner on. I know having the air on runs my radiator fan but, when it is off the temp just keeps going up. I'm not sure if the sensor on the thermostat housing is bad or its something else because my gage seems to be giving me a good reading. Does anyone have a suggestion how I can diagnose the problem and what the normal operating temp should be?
Old Apr 14, 2004 | 11:04 AM
bogus's Avatar
bogus
Default Re: overheating on '94 (Johnk)
94's have a 2 stage fan... the first kicks in at like 225 and the 2nd at like 235... and they are 2 speeds...
check the fan relay... I would think you might have an electrical problem.
do you have the helms manual? if not, you must get one!!! without it, you won't ever solve this problem.
Old Apr 14, 2004 | 11:08 AM
vader86's Avatar
vader86
They all run hot. You should run a search in the archives and youll find hundreds of threads on the problem.
Old Apr 14, 2004 | 11:31 AM
c4cruiser's Avatar
c4cruiser
What temps do you see (digital gauge, don't trust the analog one!)?? In warm weather in city traffic, it's not uncommon to see temps around 200-230 before the secondary fan starts. As you said, running the A/C forces the secondary fan on to help with cooling.
Open the hood and let the engine run as you observe the fans. Does either fan come on? Once temps reach over 230 or so, does the secondary fan start? Will the secondary fan start when you run the A/C?? If not, you may have to replace the fan relays.
You may also have a bad thermostat if the temps are consistently too high. In any event, I would recommend having the coolant system completely flushed as described in the service manual (get the Helm factory service manual for your year). Use a 50/50 mix of a good quality green coolant and distilled water (that's the recommendation in the service manual).
You should probably replace the thermostat and you can use a 180 degree stat if you want and also have the pressure cap replaced.
Also check the front of the radiator for any debris that can be clogging the radiator core. If you look up under the car behind the front license plate, you will see the A/C condensor. Check it for debris. You should be able to see the front of the radiator through the side openings of the fiberglass shroud on the right side of the radiator. Use a stream of water to flush any junk out of the core. Messy job but this one alone may solve a lot of overheating problems.
Old Apr 14, 2004 | 12:09 PM
redcorvettedave's Avatar
redcorvettedave
Default Re: overheating on '94 (vader86)
QUOTE---------------------------------------------------
they all run HOT
:iagree: just keep an Eye on the temp gauge more often esplly in stop and go traffic and when idling for a long period of time......open window put therm on 90 turn on let heat escape thru interior air vents when you get caught in heavy traffic.... :chill: just learn how to mange in different situation also make sure trash is not covering radiator...PEACE!!!
Old Apr 14, 2004 | 02:19 PM
Cherry6speed's Avatar
Cherry6speed
John, I had the same problem. Temps kept creeping-up. I finally solved the problem by pulling the radiator out and cleaning between the fins. I found that Corvettes are vacuum cleaners. I discovered mine had plastic bags, leaves, rocks, and tons of grass jammed in it. You will not believe how awesome the radiator is until, you see how well yours is actually cooling slammed full of dirt. It takes about thirty minutes to pull it out. No biggie. Just remember to drain it at the bottom and don't get any water on your OPTI. Good luck :steering:
To overheating on '94
