seat tracks
Old Apr 14, 2004 | 04:21 PM
larryfs's Avatar
larryfs
Default seat tracks
can some explain all the different seat track from later years C4's.
I know the driver seat has the electric motor, or standard track.
how bout the passenger side?
is that always fixed all the way rearwards?
Old Apr 14, 2004 | 04:22 PM
Arisa's Avatar
Arisa
Default Re: seat tracks (larryfs)
Same as the drivers. Manual or electric.
Old Apr 14, 2004 | 04:50 PM
larryfs's Avatar
larryfs
Default Re: seat tracks (Arisa)
I have the sport seats in my 96. but the passenger side seat is fixed. doesn't move at all. is that the norm?
also, on the manual driver seat, does it have adjsutment for up and down?
or just forward and back?
Old Apr 14, 2004 | 05:01 PM
bogus's Avatar
bogus
ok... this is interesting... on the 96, there is but one control for the seats... it is shared, if I remember rightly, you have to switch between them...
2nd... if it's manual, it will have a release right below the sitee's left leg.
if it don't move, it's broke.
Old Apr 14, 2004 | 05:06 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If both are sport seats then both should move; to be sure pull the seat cushion and check the track.
Old Apr 14, 2004 | 09:05 PM
larryfs's Avatar
larryfs
Default Re: seat tracks (65Z01)
my passenger seat NEVER moved, and I thought it was "fixed" in the reart most position !! There really ins't a reason the passenger seat should move !!
it's a 96 with sport seats.
Old Apr 14, 2004 | 11:03 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
I have a 94 with standard seats and both driver and passenger seats move. They have the controls on the console.
Old Apr 15, 2004 | 09:20 AM
sraft's Avatar
sraft
Sport seats are dual power.
The wiring harness for the '94-'96 sport seats has a pair of identical connectors located under the drivers seat. If the connectors are plugged into the wrong place (reversed ), the passenger seat controls are disabled. If you can't move the seat, but can adjust the bolsters and lumbar, there's a good chance that the connectors are backwards.
Old Apr 15, 2004 | 11:23 AM
larryfs's Avatar
larryfs
Default Re: seat tracks (sraft)
that is exactly my problem. the lumbar controls work fine for both seats. just the passenger seat does not move when you choose the selector to passenger. I thought it was normal.
you said I have to take out the driver seat to get to the passenger seat connector?
thanks !!
Old Apr 15, 2004 | 11:31 AM
sraft's Avatar
sraft
It's a lot easier to work in in the area with the entire seat/track out of the way, but you might be able to get to the connectors with just the bottom cushion removed. This is one of those satisfing DIY jobs - your car will work the way it''s supposed to, and the cost is $zero!
To seat tracks
