Single mass flywheel
Old Apr 14, 2004 | 11:32 PM
chriswtx's Avatar
chriswtx
Default Single mass flywheel
Has anyone used Centerforce's singlemass flywheel #700105 for internally balanced engine with a 2 peice rear mainseal ie 400sb or 87 and older 350 blocks? What pressure plates are you using with a single mass? I need one that holds alot of HP..Thanks...
[Modified by chriswtx, 10:43 PM 4/14/2004]
Old Apr 14, 2004 | 11:33 PM
bogus's Avatar
bogus
Default Re: Single mass flywheel (chriswtx)
if it's anything like the later C4's, I would use a corvette pressure plate... or at least one designed for the corvette bell housing.
Old Apr 14, 2004 | 11:46 PM
chriswtx's Avatar
chriswtx
Default Re: Single mass flywheel (bogus)
Its designed to work with the ZF-6speed.
To Single mass flywheel
