ECM testing?
Old Apr 15, 2004 | 09:45 AM
PUREC4's Avatar
PUREC4
Default ECM testing?
Anyone know if ECM Testing can be done without mega dollar dealer equipment. If so how and what do I need :confused: If not does insurance cover hand grenades :eek: :eek: :eek: almost there.
Thanks to all who have offered suggestions :cheers:
Old Apr 15, 2004 | 12:02 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: ECM testing? (PUREC4)
The first test would be to pull codes; then try the Field Service tests on my site.
If the ECM executes these tests chances are good that it is fine.
Old Apr 15, 2004 | 12:20 PM
lallend's Avatar
lallend
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
Default Re: ECM testing? (65Z01)
Hi 65Z01,
On your site you say...
Test the ECM - Engine Running
1. Connect a 3,9000 Ohm 1/4 Watt resistor across ALDL pins A & B and start the engine.
Do you mean a 3,900 Ohm 1/4 Watt resistor or a 39,000 1/4 Watt resistor? (My guess is 3.900)
Thanks for the info!
Old Apr 15, 2004 | 12:49 PM
PUREC4's Avatar
PUREC4
No codes. Will not run long enough to preform any test while running :banghead: :banghead: email coming
Old Apr 15, 2004 | 02:59 PM
65Z01's Avatar
65Z01
Chit...looks like I need to edit my site! :bb
OK, don't give up on her; the answer is in there somewhere.
To ECM testing?
