This intake leak bad or "normal"?
Old Apr 15, 2004 | 05:52 PM
ericcer's Avatar
ericcer
Default This intake leak bad or "normal"?
I have two people tell me this looks normal and another it is not. The one guys says the intake is sitting too high and needs to be milled down to match the heads better.
What do you guys think?
[Modified by ericcer, 8:44 PM 4/15/2004]
Old Apr 15, 2004 | 05:54 PM
dgoodhue's Avatar
dgoodhue
Default Re: This intake leak bad or "normal"? (ericcer)
Picture doesn't work.
Old Apr 15, 2004 | 06:05 PM
ericcer's Avatar
ericcer
Default Re: This intake leak bad or "normal"? (dgoodhue)
I don't know what the problem is because it works for me. The picture shows that the bottom of the intake ports are wet and the top is dry. This is where the gasket is not inside the ports.
The direct link to the picture is
http://web.tampabay.rr.com/eac/vette/images/leak.jpg
[Modified by ericcer, 6:45 PM 4/15/2004]
[Modified by ericcer, 8:35 PM 4/15/2004]
[Modified by ericcer, 8:38 PM 4/15/2004]
Old Apr 15, 2004 | 06:24 PM
StealDads67's Avatar
StealDads67
Cant see it still
Old Apr 15, 2004 | 06:46 PM
ericcer's Avatar
ericcer
Default Re: This intake leak bad or "normal"? (StealDads67)
Cant see it still
Oh well, nothing I can do about it. It works from home and work for me.
Old Apr 15, 2004 | 07:05 PM
VAHROOM's Avatar
VAHROOM
Looks like some porting may be in store OR the proper gaskets may not have been used.
Old Apr 15, 2004 | 08:13 PM
93Blackrose's Avatar
93Blackrose
Have your heads been milled? If so, there is a formula you can use to get things lined up. According to the book How to Rebuild Small-Block Chevy LT1/LT4 engines, if you remove .020" or more from the combustion deck surface of the heads, corrective material removal from the intake port deck and intake-to-block rails will be necessary.
Combustion deck removal amount times 1.2 = material to remove from intake port side
Combustion deck removal amount times 1.7 = material to remove from intake manifold rails
Also, it looks from the picture you posted, that the intake gaskets were coated with high temp silicone. That could be your problem. Those gaskets should be put on dry. No silicone.
The only areas that silicone should be used is on the font and rear block surfaces.
[Modified by 93Blackrose, 8:19 PM 4/15/2004]
[Modified by 93Blackrose, 8:21 PM 4/15/2004]
Old Apr 15, 2004 | 08:25 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
You are not authorized to view this page.
^^ that's why you can see it and we can't. :beatdeadhorse:
Old Apr 15, 2004 | 08:33 PM
JAKE's Avatar
JAKE
Default Re: This intake leak bad or "normal"? (CentralCoaster)
Picture doesn't work for me either and the link told me I was 'FORBIDDEN . . ."
Jake
Old Apr 15, 2004 | 08:43 PM
ericcer's Avatar
ericcer
Default Re: This intake leak bad or "normal"? (JAKE)
I renamed the JPG because it was not all lower case. I use IE for my web browser at work and at home and some web browsers can't deal with case. I am just guessing as to why some (all) cannot see the picture.
I could not upload it to my website here at CF which normally works.
Old Apr 15, 2004 | 08:46 PM
ericcer's Avatar
ericcer
Default Re: This intake leak bad or "normal"? (93Blackrose)
The heads weren't supposed to be milled. Sounds like you are saying to it is not normal to have the gaskets looking wet.
Old Apr 15, 2004 | 10:29 PM
93Blackrose
.The heads weren't supposed to be milled. Sounds like you are saying to it is not normal to have the gaskets looking wet.
Are the intake ports on the heads wet with oil? If not, I would put it back together with new intake gaskets only using silicone on the front and rear block rail surfaces.
Old Apr 15, 2004 | 10:48 PM
JasonL's Avatar
JasonL
This pic may work better
http://shell2.lomag.net/~jhliao/other/leak.jpg
Old Apr 16, 2004 | 06:43 AM
ericcer's Avatar
ericcer
Default Re: This intake leak bad or "normal"? (JasonL)
Thanks!
Old Apr 16, 2004 | 06:53 AM
ericcer's Avatar
ericcer
This is how I picture the intake to be sitting on the engine.
To This intake leak bad or "normal"?
