hand porting crossfire manifold
Old Apr 16, 2004 | 08:56 AM
da747's Avatar
da747
Default hand porting crossfire manifold
anyone know how much more flow can be gained from porting a factory CF casting? how close can it come to an x-ram? also i see in all the porting tech articles that everyone cuts out the egr tube... could i leave that in? i live in CT and they love to stick it in our @#$ with emissions testing.
Old Apr 16, 2004 | 09:07 AM
bogus's Avatar
bogus
Default Re: hand porting crossfire manifold (da747)
ugh... as far as I know, the only way to effectively port the Xfire intake is to extrude hone it... reaching is hard...
from what I have read, you can nearly double the stock flow rates... nearly... but you need to be careful, the castings can get thin...
Old Apr 16, 2004 | 09:14 AM
da747's Avatar
da747
Default Re: hand porting crossfire manifold (bogus)
CFI-EFI did u extrude home yours, and did you leave the swirl plates in? what do u think about removing them altogether?
Old Apr 16, 2004 | 10:24 AM
Dominic Sorresso's Avatar
Dominic Sorresso
da747,
This is my manifold and it has been Extrude Honed
This is what my diffuser plates look like:
If you go to the Xfire Forum, you'll find that Ken did some flow bench work on ported manifolds. It appears that porting a Xfire will increase cfm to about 200cfm per runner. EH claims a 15-30% increase in flow. Unfortunately I haven't had the opportunity to flowbench my manifold. Maybe one day I will.
Its not cheap to have a Xfire EH'd. As for the wire mesh below the diffuser, not sure why you'd go through the bother of reducing restriction and then using wire mesh.
Old Apr 16, 2004 | 10:50 AM
CFI-EFI's Avatar
CFI-EFI
I did NOT Extrude Hone mine. It is all hand ported, by me. I left the EGR channel intact, and still ended up with a 3 pound coffee can 7/8th full of grindings. Besides matching the ports, similar to Dominic's photo, I ported the full length of the runners. Unfortunately, I have no photos. Also, I have no flow numbers. I DO know that my porting was good for better than a half second in the 1/4 mile with stock bore TBs. I left my swirl plates in and they look similar to Dominic's. I have no proof or side by side comparisons, but I feel my work is competitive with an X-Ram. I shift my A4 at about 6000 rpms, with a completely stock, 160,000 mile long block. I think that, and my ETs, speak for themselves. Good luck, and...
RACE ON!!!
Old Apr 16, 2004 | 11:16 AM
da747's Avatar
da747
Default Re: hand porting crossfire manifold (CFI-EFI)
what did you use to port inside the runners? thank you
Old Apr 16, 2004 | 11:29 AM
Dominic Sorresso
I'd agree with CFI that a ported Xfire will easily run with the
Xram manifold lid and the Weind manifold base. The cost is a little time and elbow grease. Well worth it IMO. In fact, until I swapped cams, I would easily pass Illinois Emissions Testing including the drive cycle.
[Modified by Dominic Sorresso, 10:30 AM 4/16/2004]
Old Apr 16, 2004 | 11:38 AM
corvetteII's Avatar
corvetteII
5th Gear
I'm right there with you da747. I want to port my stock Xfire intake as well, so if you find out anything else about it, post it and hopefully we can both gain significant power gains from this.
Adam
Old Apr 16, 2004 | 11:43 AM
CFI-EFI's Avatar
CFI-EFI
Carbide bits and drill bit extensions.
RACE ON!!!
Old Apr 16, 2004 | 11:50 PM
da747's Avatar
da747
Default Re: hand porting crossfire manifold (corvetteII)
Adam check out http://crossfire.homeip.net they have a pretty nice xfire porting article.
Old Apr 17, 2004 | 11:42 AM
nobodyunknown's Avatar
nobodyunknown
I think the throttle bodies will not flow as much as a stock ported manifold will already allow.
In another words unless you get much bigger throttle bodies your wasting your time.
As far as performance gain you may see some top rpm power, you will loose low end torque.
The crossfire is all about low end torque.Its a point & squirt type driveing car.
Old Apr 17, 2004 | 12:53 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: hand porting crossfire manifold (nobodyunknown)
Key words... I think. Have you done it or are you speculating. How would you , "see some top rpm power" with inadequate sized TBs? If the TBs are too small, why, "you will loose low end torque." would you lose low end torque?
At the risk of repeating myself, *I* gained over a half second in the 1/4 mile from my ported manifold, with the stock TBs. Two weeks later, I installed TBs bore out to 2". I received no additional gain from the larger TBs. Since I had no loss either, I left them in place. Possibly with a little better exhaust, they are now contributing to the cause.
Idle speculation is one thing. The proof is...
RACE ON!!!
To hand porting crossfire manifold
