3rd brake light replacement - HELP
Old Apr 16, 2004 | 03:47 PM
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
CI 4-6-8 & 10 Veteran
St. Jude Contributor
Default 3rd brake light replacement - HELP
I have an 86 convertible with the third brake light in the rear bumper section. I have found references to how to change the brake lights by reaching through the plate hole, but when I do that I can't feel where there are any connections. Am i just giving up too easy, or is there a trick for the third light that I have missed?
Old Apr 16, 2004 | 04:36 PM
maduraj's Avatar
maduraj
Default Re: 3rd brake light replacement - HELP (Fozzy_Bear)
Mine is a different year, but I think the third light might be the same. On mine, the connections to the light are at the center and bottom of the light assambly, not on the back. Hope that helps.
Old Apr 16, 2004 | 05:26 PM
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
Default Re: 3rd brake light replacement - HELP (maduraj)
So how would I change a bulb? Do you mean they come out from the bottom?
Old Apr 17, 2004 | 01:46 AM
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
ttt
:D
[Modified by Fozzy_Bear, 1:45 PM 4/17/2004]
Old Apr 17, 2004 | 01:46 PM
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
:D
Old Apr 18, 2004 | 11:46 AM
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
One last TTT before I give up and pay the local shop.
Old Apr 18, 2004 | 12:18 PM
maduraj's Avatar
maduraj
yep, the bulb is at the bottom of the light assambly. If you reach up there, you should be able to feel the wires. Follow the wire to the light, and that should lead you to the light bulb connector. Once you get to the connector, turn the connector about 45 degrees and the light bulb should come out. You might want to take a flash light and shine it up by the license plate light. I think you might be able to see the connector that way.
Old Apr 18, 2004 | 02:50 PM
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
To 3rd brake light replacement - HELP
