Crank balancer hub remove/replace ????
Old Apr 17, 2004 | 08:15 PM
LT4Abe's Avatar
LT4Abe
Default Crank balancer hub remove/replace ????
Has anyone been able to change the harmonic balancer hub seal without taking the waterpump off??? If so, whats the best way to do it??
Thanks a lot!!!!!!
Old Apr 18, 2004 | 01:32 AM
BLIZZ's Avatar
BLIZZ
Default Re: Crank balancer hub remove/replace ???? (LT4Abe)
Sorry, only way to access the balancer is to remove the H20 pump!! While you are at it, depending upon your mileage, you might consider replacing the Optispark at the same time. :eek:
Old Apr 18, 2004 | 12:13 PM
LT4Abe's Avatar
LT4Abe
Thanks, man I was really hoping I wouldn't have to do it all again, I just replaced the w/pump and opti. But I skipped that seal and it leaks from that are. What a coincidence of that seal going the same time the w/pump went!!!!!
To Crank balancer hub remove/replace ????
