First time at track with nitrous
Old Apr 18, 2004 | 04:47 PM
shepsvettes's Avatar
shepsvettes
Default First time at track with nitrous
Had my first time at the track since my nitrous install today. Conditions were terrible 40 mph winds and very high humidity. Best times were as follows
Reaction tine .039 60 ft 2.189 Et 13.178 MPH 110.856
I didn't think that was to bad for first time and a 2.59 gears
Old Apr 19, 2004 | 06:33 PM
Thumper's Avatar
Thumper
Cruise-In II Veteran
Default Re: First time at track with nitrous (shepsvettes)
What did you run before the Nitrous install and how much of a shot were you running?
Old Apr 19, 2004 | 07:46 PM
shepsvettes
Was unning about a 14.00 100 mph Im running a 100 shot My 2.59 gears are killing me and I know it
Old Apr 26, 2004 | 01:41 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I see with a 2.1 60 ft your tires were spinning or you did not use the nos until
you were down the track a way's, you should pick up a little more than one second with the 100 shot if tuned right.gears are ok nos doesnt know the difference ,but the mph is where it should be ,and by the way nos loves high heat and humity you just have to work with the fuel pressure a bit.
I use 75 shot and turn 112.43 mph and 12.29 with the 125shot 11.72 at 115.89
STOCK RUN WITHOUT NOS 13.49 103.55
[Modified by REDC4CORVETTE, 6:43 AM 4/26/2004]
[Modified by REDC4CORVETTE, 8:57 AM 5/12/2004]
Old May 6, 2004 | 02:10 PM
mike 1985's Avatar
mike 1985
Default Re: First time at track with nitrous (REDC4CORVETTE)
i ran the same MPH as you 110, my ET was 11.91...the difference is my 60' was 1.61 on that run. Sticky tires and turning the spray on sooner will help my friend.
To First time at track with nitrous
