Started new engine, got serious problems
Old Apr 18, 2004 | 05:58 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Fixed!
[Modified by NUckINg FuTS, 10:02 PM 5/2/2004]
Old Apr 18, 2004 | 06:12 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Started new engine, got serious problems (NUckINg FuTS)
Double check all your plug wires? Your rough running could be related to that, although it wouldn't explain the hard starting.
Old Apr 18, 2004 | 06:40 PM
NUckINg FuTS
Default Re: Started new engine, got serious problems (Nathan Plemons)
Double and triple checked wires. Everythings where it should be
Old Apr 18, 2004 | 08:10 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
is it a internal or external ballenced assy that will make a huge difference :cheers:
Old Apr 18, 2004 | 10:13 PM
NUckINg FuTS
Default Re: Started new engine, got serious problems (CORKVETTE1)
External.
Old Apr 19, 2004 | 02:54 AM
olman's Avatar
olman
Did the flex plate come with the engine? The rpm range you describe is where they shake if badly out of balance. Why did the previous owner get rid of the engine? Not all 383s are externally balanced. Good luck on this one!
Old Apr 19, 2004 | 04:17 AM
kman0066's Avatar
kman0066
Default Re: Started new engine, got serious problems (olman)
Are you getting any back-firing? Might re-check the valve-lash.
Old Apr 19, 2004 | 10:05 AM
NUckINg FuTS
No, the flexplate did not come with the engine. I bought a standard balanced 400 flexplate. How can you tell if an engine is internally balanced???
Old Apr 19, 2004 | 10:15 AM
rick lambert's Avatar
rick lambert
Machine shop records-or a complete tear down,when an engine is internally balanced-a good machine shop will give you records, at least mine did. Sounds like an ignition problem-or valve train problem :(
Old Apr 19, 2004 | 02:12 PM
JAKE's Avatar
JAKE
[SNIP]No, the flexplate did not come with the engine. I bought a standard balanced 400 flexplate. How can you tell if an engine is internally balanced???[/SNIP]
One way is to look closely at the flexplate and the harmonic dampner to see if there are extra weights on them. This would normally indicate that the engine is EXTERNALLY balanced. That's ASSUMING that they are the correct parts for the engine to begin with.
Another, more reliable way, is to drop the oil pan and look at the crankshaft. If the engine is INTERNALLY balanced you should see locations where Mallory metal has been added. They will look like round slugs in the butterflies which are slightly larger than the diameter of a quarter.
You can also call the shop that worked on the assembly to see if they have a record of which way it was balanced, if, in fact, it ever was.
Jake
To Started new engine, got serious problems
