84 manifold
Old Apr 19, 2004 | 08:25 AM
da747's Avatar
da747
Default 84 manifold
Is the manifold base and plenum interchangable between the 82-84 camaro, firebird and corvette? thanks
Old Apr 19, 2004 | 09:09 AM
bogus's Avatar
bogus
Default Re: 84 manifold (da747)
uh, why?
The Firebird used a 305... and I am sure as I can be when I say, it won't flow worth a damn.
Old Apr 19, 2004 | 09:53 AM
joesred84's Avatar
joesred84
Yes, but the 305 injectors are different.
Old Apr 19, 2004 | 10:32 AM
pr0zac's Avatar
pr0zac
Default Re: 84 manifold (joesred84)
:iagree:
Old Apr 19, 2004 | 10:34 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Go to http://www.crossfire.webhop.net
Good Info there!
tony
:thumbs:
[Modified by oldace84, 7:34 AM 4/19/2004]
Old Apr 19, 2004 | 11:12 AM
da747's Avatar
da747
Default Re: 84 manifold (bogus)
uh, why?
i want to try to port my manifold, but if i screw up i want a backup, plus so i can drive the car and not rush.... so i want to know if i can get any manifold.
Old Apr 19, 2004 | 11:13 AM
CFI-EFI's Avatar
CFI-EFI
They are not only interchangable, they are the same parts. The Crossfire was used 1982-1984. There are two different bases. One has "balance holes" between some of the runners, and the other doesn't. With or without balance holes was a year model distinction, not an engine size difference. When I ported my manifold, I bought a "spare" rather than tie the car up. The spare had the "balance holes". I epoxied them closed. I can't imagine it makes much difference, either way.
RACE ON!!!
Old Apr 19, 2004 | 11:31 AM
da747's Avatar
da747
Default Re: 84 manifold (CFI-EFI)
thanks CFI!
To 84 manifold
