bushing kit questions....
Old Apr 19, 2004 | 03:49 PM
brookman's Avatar
brookman
Default bushing kit questions....
Does anyone make a complete suspension bushing kit ? If so - who. If not - what do I need to order? I have an '88 with the z52.
Thanks.
Old Apr 19, 2004 | 10:17 PM
okinawa86vette's Avatar
okinawa86vette
Default Re: bushing kit questions.... (brookman)
Energy makes a set. It inlcudes everything except the swaybar bushings, being how there's so many diff sizes. The black set is poly-graphite and the red is regular polyurethane. I'd get the black, they don't sqeak unless you're going over speed bumps or really rough pavement.
http://www.energysuspension.com/corv1.html It's the first Hyperflex kit in blue down the page a little ways.
Summit and Jegs both carry the kit, both around 180 or so. It's an excellent kit and they're customer service was excellent as well. They shipped me a new bushing free of charge when I split it accidentally installing it. Had it in my hands 3 days later.
Chris
Old Apr 20, 2004 | 05:12 PM
brookman's Avatar
brookman
Default Re: bushing kit questions.... (okinawa86vette)
Are the swaybars listed by diameter?
Old Apr 20, 2004 | 05:32 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Yes they are.....
Old Apr 20, 2004 | 06:41 PM
RonRed89's Avatar
RonRed89
How long does it take to change to the poly bushings assuming that you bought a set like the one indicated in this thread from Energy?
(I have access to a lift and tools).
Thanks,
Ron
Old Apr 20, 2004 | 07:14 PM
Trog's Avatar
Trog
Default Re: bushing kit questions.... (RonRed89)
Doesn't take all that long. A press is a must though for some of the bushings. The batwings are at PITA. I took the time to file off all the casting marks & polish up most of my parts though & that took the most time... Don't know what I was thinking :crazy: ...
Old Apr 20, 2004 | 11:15 PM
RonRed89's Avatar
RonRed89
Default Re: bushing kit questions.... (Trog)
I don't know what you were thinking either, but you sure thought right. That suspension looks great!
How did your XtraGrip install go? Is the relocation of the mounting holes for the coil overs really that bad?
Ron
Old Apr 20, 2004 | 11:21 PM
Trog's Avatar
Trog
Thanks! :cool:
No, it wasn't really that bad. Might have spent at most 2 hours per side with fabrication. But I admit to being a nitpicker & welded in some 1/2 moons of steel when I moved the large hole forward where the shock tower fits up into the frame. An air die grinder w/ a cutoff wheel (worn down to size) made short work of grinding the hole forward. Someday I'll break down & buy a plasma cutter.
:cheers:
To bushing kit questions....
