have u ever tried............
Old Apr 20, 2004 | 07:03 PM
waterdogvette's Avatar
waterdogvette
Default have u ever tried............
fit a 315/ 35 -17 on 9.5 wheels??? they are made to fit on a 11 inch. i know!! but i dont know if i want to get rid of my sawblades ..im thinking on the rear only.. :hat :troll
Old Apr 20, 2004 | 08:29 PM
Alchemist's Avatar
Alchemist
NC Events Coordinator
Default Re: have u ever tried............ (waterdogvette)
I've seen folks with 315s on 9.5s...and they looked ok...but they didn't wear for nuth'n. IMHO...Not a good idea.
Old Apr 20, 2004 | 10:16 PM
Perfusion's Avatar
Perfusion
Default Re: have u ever tried............ (Alchemist)
:iagree: :iagree: :iagree:
Old Apr 20, 2004 | 10:50 PM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Default Re: have u ever tried............ (Perfusion)
If you want 315's on the back, but want to retain the sawblades, try to find some '91/'92 ZR1 rears. 315's can be physically mounted on a 9.5" wheel, but it's a bad idea.
Old Apr 20, 2004 | 10:53 PM
96BLKTN's Avatar
96BLKTN
IF ONLY THEY MADE A 295 OR 305(40/35/17)...............................NOW THAT WOULD BE :cool: AND I WOULD BUY IT :cheers:
Old Apr 20, 2004 | 10:55 PM
96BLKTN's Avatar
96BLKTN
Default Re: have u ever tried............ (CorvetteZ51Racer)
91/92 ZR-1 used a 36mm offset it stick out and look like a high school kid with a vette.
Old Apr 20, 2004 | 11:01 PM
h rocks's Avatar
h rocks
Good idea on matching the wheel design, but on an 88+ up car, they are going to be protruding beyond the fender lip by probably a good 3/4 -1". If the car is lowered or the suspension goes into full bump, it's going to bottom out on the fender lip rather than the bumpstops.
While I wouldn't do it, it's not the end of the world for a 315 to be fit on an 9.5" wheel for a "driver".
Old Apr 20, 2004 | 11:18 PM
CorvetteZ51Racer
Default Re: have u ever tried............ (h rocks)
Crap...forgot about the offset thing...nevermind
Old Apr 20, 2004 | 11:25 PM
Trog's Avatar
Trog
I run 285/40/17 on my 9.5's & they fit real nice.
Old Apr 21, 2004 | 04:57 PM
waterdogvette
thank u guys!! i will try... nothing to loose i already have the tires.. :blueangel:
Old Apr 21, 2004 | 07:26 PM
McShagger's Avatar
McShagger
Dude, its definately a bad idea. If you are driving at high speeds the sidewalls will heat up and weaken and eventually a blowout is iminant.
Old Apr 21, 2004 | 08:22 PM
MrNuke's Avatar
MrNuke
I did.
Looked VERY nice, but I had less traction than stock tires, as the contact patch wasn't perfect on teh 9.5" wheels..
Old Apr 21, 2004 | 08:45 PM
waterdogvette
Hmmmmm........... :confused: :confused:
Old Apr 21, 2004 | 08:52 PM
ZF Six's Avatar
ZF Six
Default Re: have u ever tried............ (96BLKTN)
... and look like a high school kid with a vette.
Present. :D
But meanwhile I have seen a 315 mounted on a 9.5" rim, and IMO -- :nonod:
The tire practically folds over the lip of the rim, probably has a good 3/4-1" of tire past the rim, just get a 285, that should work fine.
[Modified by ZF Six, 7:54 PM 4/21/2004]
To have u ever tried............
