Still getting "SYS"
Old Apr 15, 2004 | 02:41 PM
jabez's Avatar
jabez
Default Still getting "SYS"
I scanned for errors and it came up without any. Cleared all codes, and unhooked battery. Still getting that irritating "SYS'' message on dash?
Anybody with any solutions? :confused:
Old Apr 15, 2004 | 03:07 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Still getting "SYS" (jabez)
Is it constant or intermittent? Are there any codes now?
Try pulling the codes using a paper clip between A&B at the ALDL. If the SES won't flash, check for a short in the Brn/Wht wire from the 15-way connector from the SES light bulb to the ECM at pin A5.
If the wire is on you likely have a problem with the CalPac (did you have it out recently?) or the ECM.
BTW, you can clear the codes by opening the connector in the Or wire near the battery for 1 minute; this preserves your clock & radio presets.
[Modified by 65Z01, 3:14 PM 4/15/2004]
Old Apr 15, 2004 | 04:11 PM
Steel Blue 91's Avatar
Steel Blue 91
If the SYS light is flashing in the speedo display, I'd look at having the battery tested. It might be the first indication of one that's on the way out.
Old Apr 15, 2004 | 04:19 PM
vvv90's Avatar
vvv90
Before you do ANYTHING, replace the battery if it's due to be replaced.
Old Apr 15, 2004 | 04:57 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
Default Re: Still getting "SYS" (Steel Blue 91)
:iagree:
Old Apr 21, 2004 | 03:35 PM
jabez's Avatar
jabez
Default Re: Still getting "SYS" (Z-07 freak)
Ok...I replaced the battery today. One hour to take old one out and 5 minutes to install new one (first time). Still getting those intermittent flashing
"SYS". I am lost now. :confused:
Old Apr 21, 2004 | 04:22 PM
Steel Blue 91
Did you recently install or have installed an aftermarket stereo head unit?
Old Apr 21, 2004 | 05:25 PM
Ramrod92's Avatar
Ramrod92
Ben, read this thread and if you have any more questions, just shoot me an email and I'll try to send you the procedure from the service manual that you use to find out what code is set in the CCM. http://forums.corvetteforum.com/zerothread?id=799993 :steering:
Old Apr 21, 2004 | 07:41 PM
jabez's Avatar
jabez
Default Re: Still getting "SYS" (Ramrod92)
Thanks... I will try this next.
Nothing will happen if I don't take care of it right away will it?
Old Apr 21, 2004 | 09:05 PM
DVNCI's Avatar
DVNCI
I didn't see what year car you have, I have a 96' with an OBD-I conversion and that will cause it as well. That will show a Code 81 in the CCM.
Once you read the code you'll have a good idea.
It doesn't hurt a thing.
To Still getting "SYS"
