Muffler Change?
Old Apr 21, 2004 | 09:53 AM
MostWanted's Avatar
MostWanted
Default Muffler Change?
I've always heard that the Corvette already has a good exhaust system. Still, I see a lot of members who get new cat back exhausts. How much more power do you really get from the cat back system? I also realize that some people change it out for the sound. My question is... can I benefit in the sound or performance field with just a muffler change? If so, what is the preferred brand? Thanks in advance for the suggestions! :thumbs:
Old Apr 21, 2004 | 09:54 AM
bogus's Avatar
bogus
Default Re: Muffler Change? (TorchRedXCVI)
I replaced my exhaust to remove that annoying resonance at highway speeds...
Hence, Corsa's. Is there a power improvement? I donno.
:lurk:
Old Apr 21, 2004 | 02:42 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Sound is a matter of choice. Search the archives and you'll find more than you can stand to read. As for performance, the CF consensus seems to be the major brands of catbacks are all good for 10-15HP with a basicly stock engine. However, a while back I did some research on this and posted a few questions and it seems the LT1/LT4 exhaust is not that bad (definitely better than the L98) and that generally speaking, two-thirds of the performance gains comes from the respective mufflers and not the aftermarket pipes. Here are a few old threads of mine to get you started:
http://forums.corvetteforum.com/zerothread?id=752805
http://forums.corvetteforum.com/zerothread?id=767188
Old Apr 21, 2004 | 04:31 PM
McShagger's Avatar
McShagger
The stock exhaust system is pretty good. But the stokc mufflers are not very good. Sure they are quiet, but they have too many chambers that will restrict the airflow. Get rid of them and put something with better airflow on. I have no data to prove it, but it seems like the theory of straight through design works the best to me.
Old Apr 21, 2004 | 09:36 PM
TOO_HOTTVETTE's Avatar
TOO_HOTTVETTE
I have also heard that the stock LT1/4 exhaust system is pretty darn good. The pipes are huge! I think the flow advantages to the aftermarket systems are mainly in the mufflers. However you do get the nice stainless steel with the after market systems. Maybe some aftermaket system offer a weight advantage? I'm sure the restrictions on the stock sytem are the exaust manifolds, cats, and mufflers. So long tubes and good free flowing mufflers should outperform a catback.
[Modified by TOO_HOTTVETTE, 9:36 PM 4/21/2004]
To Muffler Change?
