Good Cam Choice?
Old Apr 23, 2004 | 07:40 PM
mos90's Avatar
mos90
Default Re: Good Cam Choice? (ANTI VENOM)
anti, i never said "those" cams would idle better. i was just stating that you can find cams in the same duration range as the hot cam with less centerline that will idle a little better. the first cam i picked would be best for a 383. the second for an aggressive 350. but like someone mentioned it would be way to much for a stock converter, that why i like my 6 speed. :steering:
Old Apr 23, 2004 | 09:37 PM
mos90's Avatar
mos90
Default Re: Good Cam Choice? (mos90)
i just ordered my tpis/afr heads for my 91 and im going to go with zz409.
it is 226/226 .554/.554 with 1.6. this car is really not a daily driver, only put on about 2000 miles and i also have a 6-speed. but realisticly this about as big as you can go in a 350 unless you turn 7000 rpm's or dont really drive on the street often.
Old Apr 27, 2004 | 09:59 AM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
Default Re: Good Cam Choice? (mackeyred96)
Call Cartek and they can sell you my head and cam combo complete, You wcan't beat the performance.
hummmm that may be something to think about
