MASS AIR FLOW RELAYS ????????????????????????????????
Old Apr 22, 2004 | 07:13 PM
wirenut3's Avatar
wirenut3
Default MASS AIR FLOW RELAYS ????????????????????????????????
Hi I bouught 2 new relays for my 1986 late model Vette the burn off relay and the power relay BUT whitch one is what I know they are behind the battey one is flat agianst the fire wall and the other is lenth was of the car so can any one tell me witch one is what thanks. :cheers:
Old Apr 22, 2004 | 07:25 PM
Black87c4's Avatar
Black87c4
Default Re: MASS AIR FLOW RELAYS ???????????????????????????????? (wirenut3)
They use the same relay so unless you just really want to know which is which replace both. As to tell you'd have to follow the wiring diagrams and wiring color since you'd never know if someone swapped the connectors between each other before.
Old Apr 22, 2004 | 07:43 PM
wirenut3's Avatar
wirenut3
Default Re: MASS AIR FLOW RELAYS ???????????????????????????????? (Black87c4)
thanks for the reply :cheers:
Old Apr 23, 2004 | 08:27 PM
wirenut3's Avatar
wirenut3
I replaced both relays the vette runs alot better now plus better gas milege Thanks :cheers:
Old Apr 23, 2004 | 09:25 PM
Black87c4's Avatar
Black87c4
Good deal :thumbs:
Old Apr 24, 2004 | 06:05 PM
wirenut3's Avatar
wirenut3
Thanks :seeya
To MASS AIR FLOW RELAYS ????????????????????????????????
