Please help me ASAP!
Old Apr 23, 2004 | 09:27 PM
MongooseLT4's Avatar
MongooseLT4
Default Please help me ASAP!
I need to know the tq specs for the waterpump on an LT4 and also when you seal the pump, Do you just use the paper gaskets or is it better to cover both sides of the gasket with grey RTV? Thanks a bunch for your help everyone!
Old Apr 23, 2004 | 09:35 PM
MostWanted's Avatar
MostWanted
Default Re: Please help me ASAP! (MongooseLT4)
Chilton says: Before you assemble the coupling to the water pump, apply a light coat of grease to the seals and splines. a)install the coupling with the groove toward the engine. b)Install new gaskets with the tabs up, the water pump with the drive coupling and the mounting bolts. Tighten the bolts to 30 ft. lbs. :thumbs:
Old Apr 23, 2004 | 09:41 PM
MongooseLT4
Default Re: Please help me ASAP! (TorchRedXCVI)
thank you thank you
[Modified by MongooseLT4, 9:58 PM 4/23/2004]
Old Apr 23, 2004 | 09:47 PM
MostWanted's Avatar
MostWanted
No problem...glad to help! :thumbs:
To Please help me ASAP!
