Power steering issue
Old Apr 26, 2004 | 09:36 AM
Unriced's Avatar
Unriced
Default Power steering issue
Recently replaced hi pressure hose and now I am getting foamy fluid
and a whine from the pump. It did not do this initially after replacing the hose,
so if any of you have a surefire way to get the air out, or what I am doing
wrong, please let me know.. Thanks
Old Apr 26, 2004 | 09:45 AM
bogus's Avatar
bogus
Default Re: Power steering issue (Unriced)
top off the fluid and crank the wheel left and right a few times... lock to lock.
that should remove any air in the system....
Old Apr 26, 2004 | 09:49 AM
Unriced's Avatar
Unriced
Default Re: Power steering issue (bogus)
Should this be done with the car off and the front end jacked up?
Or do I start 'er up and go lock to lock?
Old Apr 26, 2004 | 09:51 AM
96LT1's Avatar
96LT1
:iagree:
The service manual says something like...
1. Jack the car up in the air.
2. 10 turns lock to lock with the motor off.
3. Top off with fluid.
4. Start the car
5. 10 turns lock to lock.
Works like a champ.
Old Apr 26, 2004 | 10:17 AM
Unriced's Avatar
Unriced
Default Re: Power steering issue (96LT1)
Thanks all, I'll give it a shot..
Old Apr 26, 2004 | 10:24 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
:iagree:
4. Start the car
Works like a champ.
Actually if you have a power steering cooler, you need to turn it lock to lock 40 times.
Old Apr 26, 2004 | 10:35 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Power steering issue (Mr Mojo)
:iagree:
4. Start the car
Works like a champ.
thats a fact jack... :iagree: :thumbs:
To Power steering issue
